16-06-2005, 01:01 AM | #1 | ||
Kaddis Customs
just wondering am i able to take a steering wheel from an AU xr and put it into my EF??
anyone know if these are hard to find/expensive??
FG XR6 E-Gas Ute in Ego |
16-06-2005, 01:01 AM | #2 | ||
Low and Loud
Yes AU wheels will fit EF/EL
EFFALCON has a AU one if im correct.. that steeringwheel is availble on EBay and sold at ford aswell... Blue/black/Silver/Red are the colours available IIRC
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon : |
16-06-2005, 01:09 AM | #3 | ||
Kaddis Customs
nice! i found them for about $275 but that's without the center pad or any of the center
main reason why i was looking for another wheel is because my air bag isn't working and im 95% sure it's the actual bag
16-06-2005, 01:21 AM | #4 | ||
Last warning
the air bag is an expensive replacement.
how do you know the air bags not working? there is a problem that when the air bag fuse blows, u have to reset the system to clear the fault.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
16-06-2005, 01:27 AM | #5 | ||
Kaddis Customs
how do you reset the system then?? caus the horn was not working i checked the air bag fuse and it was blown so replaced that then reconnected the horns(don't know why there were disconnected:S) and the horn works fine now but air bag like still is on
when i first start the car and in say the first minute of so it kinda comes on and off then eventually stays on also what can caus the air bag fuse to blow?
16-06-2005, 01:35 AM | #6 | ||
Last warning
yep
you need to reset the air bag system. if you're not a member on fordmods, then join up and look here: hxxp://www.fordmods.com/phpBB2/documents.php?doc=3 look at the section on clearing codes.
16-06-2005, 02:59 AM | #7 | |||
Social Disaster
1995 EF Falcon GLi, Auto, 4.0L I6 Mods: 3.73 LSD | Darkest legal tint | tinted back lights | Sprayed Dash | Custom Trims Sound System: Fusion front splits, rear 3-ways, and 2 x 12" subs with ctrl, 3 x Fusion amps | Clarion HU | 1F Cap | 60GB Zen Xtra | 800W RMS output! |
16-06-2005, 07:08 AM | #8 | ||
are they much thicker then the el xr6 steering wheel?
16-06-2005, 08:32 AM | #9 | ||||
02 BA XR6 T U R B O Venom Red, Auto 13.97 @ 101mph Quote:
16-06-2005, 11:57 AM | #10 | ||
Last warning
Yeah, AU and EF/EL wheels are interchangable.
you can just whack your EF/EL airbag onto it and you're laughing (except for the colour) i painted mine with vinyl dye so its black like the steering wheel, been good so far mrbt1: the AU momo steering wheels are an awesome wheel to hold, much nicer to hold then the normal XR ones.
16-06-2005, 09:38 PM | #11 | ||
Custom user title
If the horns not working and the air bag light is on.. Clock spring is most likely broken
16-06-2005, 09:40 PM | #12 | ||
Last warning
the horn works fine now :P
