Old 16-06-2005, 05:41 PM   #1
jedaarr
jedaarr's Avatar
Location: Nowra (Southcoast) N.S.W. Beutiful beaches no smog & plenty of grog & yes that is my dog.
Default Engine mounts busting.
I have had fords for many years but notice
that E series engine mounts break quiet
often on the Welded area (rubber to steel.)
I replaced mine 2 months back & already
the left side has pulled away again.
The car is a manual - i often give it a bit
of juice from take off, but i cant see mounts
lasting such a short time.
Does anyone know of stronger mounts
or how to make them stronger.
HOME BREW BEER SWINDLING PROFFESIONAL P-HEAD.
TO MANY YEARS IN THE MAKING : :1syellow1
jedaarr is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2005, 09:09 PM   #2
EASPRINT
FPV GT-P 335!
EASPRINT's Avatar
I work at repco....and i know our ford six mounts are hopelesss....I will only use original ford ones......There the best!....i fitted new ones 12months ago on my turbo...and still sweet now!
Current rides - 2013 FPV GT-E MK2 & 2010 FPV F6-E
Tuned by Michael J's & Son.
EASPRINT is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2005, 09:17 PM   #3
eb six on boost
NO CARBON TAX
eb six on boost's Avatar
i welded steel plates down the sides of rubber blocks, problem solved
THE WORLDS FASTEST BISCANYE BLUE EB FALCON WITH EB BLOCK AND HEAD!!! NO AU **** THANKS
Atomic performance engine, powerglide, coan converter, gtx55 turbo, 2000hp plazmaman water to air, 100mm throttle body, twin 50mm gates, side exit exhausts, 18 x 2200cc injectors, ems 8860 and race dash.......
7.83 @ 177 MPH
1100+ rwhp @ 40psi
the first 7 second sohc ! eat it
1993 eb falcon 15.4 @ 90mph (tow car)
eb six on boost is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2005, 09:40 PM   #4
EB6
apprentice grease monkey
EB6's Avatar
if ya dont mind a bit of a dodge job, then what ya can do is put a big *** bolt through the mount to hold it in place just give it a couple of mm of free play then have it welded in place. this will make ya car rock back and forth durning revving tho, (scares 4 bangers tho).
EB6 is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2005, 02:58 PM   #5
neb
hibernating
neb's Avatar
yeah i bought non ford engine mounts once... they didn't even last a day! definately get engine mounts from ford. and also if you're getting axle tramp or anything that can cause you to break mounts. i found my problem was i had the rear of my wagon lowered with lowering blocks which pushes the diff up out of alignment and that was giving me problems... lowered it properly with lowered leafs and got ford engine mounts in and havn't had a problem since then (about 6months now)
neb is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2005, 06:14 PM   #6
jedaarr
jedaarr's Avatar
(EA SPRINT) what is it about the genuine ford mounts that
is so good, I dont care about cost as it is a pain in the ***
when u try to take off with your engine bouncing all over
the place & missing gear changes.
Welding sounds good as u see in posts, but i would rather
just do new mount change.
Thank u to all of the ford forums comments & ideas.
Old 18-06-2005, 07:47 PM   #7
EASPRINT
FPV GT-P 335!
EASPRINT's Avatar
The genuine ford mounts just work better and last longer....And they shouldn't cost more than $30 each.
Old 18-06-2005, 09:13 PM   #8
Dezza
Parts bin special
Dezza's Avatar
When I bingled by car, I had to replace 3 of the engine mounts, as the engine was shunted backwards in the impact (but somehow not damaged). One of the new mounts failed just about right away, and it stayed like that for a while! Under acceleration, the car sounded like an absolute dog... "groan groan clunk". We finally replaced it with a genuine one, and gee it made a difference.
Old 19-06-2005, 11:52 AM   #9
PULLY6
PULLY6's Avatar
what causes the T section to get bent out of place? constant fast-changing revs?
1998 Ford Fairlane - 4.0L
18x8 RJR rims - Tinted - King Suspension - 2.5" D&T Cat Back Exhaust
PULLY6 is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2005, 02:32 PM   #10
Walkinshaw
Two > One
Walkinshaw's Avatar
Originally Posted by ea_silver_ghia
When I bingled by car, I had to replace 3 of the engine mounts.
Funny that mine only has 2 mounts.
Old 19-06-2005, 04:43 PM   #11
Dezza
Parts bin special
Dezza's Avatar
Oops. My uncle did the repairs so I didn't know the exact details but all I knew was that one mount survived. It was my parent's car at the time so they paid for the repairs. I just presumed that there were 4 so I was obviously wrong.
I'll just keep my mouth shut now.
Old 30-01-2006, 06:13 PM   #12
Gubas
- BOOYEH -
Gubas's Avatar
Well, it would appear that I have busted my engine mounts. Looks easy enough to replace the one nearest the exhaust, but the one nearest the intake looks a bit harder. For those who have done these before, is it doable replacing the mount from under the car, or does the intake manifold have to come off?
I will buy genuine mounts from ford tomorrow.
Thanks guys.
1993 EBII Fairmont Turbo T04e 7 psi
Gubas is offline   Reply With Quote Multi-Quote with this Post
Old 30-01-2006, 06:25 PM   #13
Simmo
White Lightning
Simmo's Avatar
i've seen it done from under the car on an eb. looked hard though.
Simmo is offline   Reply With Quote Multi-Quote with this Post
Old 30-01-2006, 09:32 PM   #14
INJECTED_250
Custom user title
INJECTED_250's Avatar
droping the clutch while towing a tandem with a car on it back from heathcote seems to be a recipie for breaking repco engine mounts... I managed to break 2 engine mounts and im pretty sure the gear box mount all in one go.....
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
Old 30-01-2006, 09:56 PM   #15
The Goodz
E-Series Firemaker
The Goodz's Avatar
The Ford mounts are pretty decent and are reasonably priced, well for an employee anyway $50 for the pair. That's the EA-ED style mounts...
Although with my engine I've already gone through 2 sets in 12 months.
Alex
The Goodz is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2006, 10:20 PM   #16
Gubas
- BOOYEH -
Gubas's Avatar
Well, I changed the drivers side mount on thursday, and changed the other today. Damn, I was really surprised to discover one very loose bolt somehow holding the mount on. The other two rattled off and god knows where they are, and the mount is completley rooted!!!!!!!!! Pulled the engine mount of in two parts. Ahh well. All is good now, and I can go to the Dyno Day tomorri, and cruising at shaggers tonite
