14-01-2005, 04:02 PM | #1 | ||
Last warning
some pics of what was under the timing case...
first of all, the timing case is broken into 3 peices... the chain guide on the intake side is connected to nothing with both ends showing damage. there was a peice of metal stuck in the crankshaft gear. there are some major metal grinding marks on the inside of the timing case. the pics :P [img]hxxp://www.deleted link/pics/mycar/failures/p1010707.jpg[/img] [img]hxxp://www.deleted link/pics/mycar/failures/p1010710.jpg[/img] [img]hxxp://www.deleted link/pics/mycar/failures/p1010711.jpg[/img] [img]hxxp://www.deleted link/pics/mycar/failures/p1010713.jpg[/img]
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
14-01-2005, 04:29 PM | #2 | |||
Burnin Rubber
Geez, looks to be a fair ole amount of damage there. So, whats the go from here, are you goin to full repair/replace the parts? or maybe a new engine?
atleast you got a fair few clicks outta the engine before it blew up.
2001 AUII Forte (LPG) K&N Air Filter Tickford Air Intake ***Coming Soon: Clear Side Repeaters*** Quote:
14-01-2005, 04:40 PM | #3 | |||
What a mess. Nothing there that cant be fixed though.
I picked up a new timing cover from for for about $80, but it was slightly different to mine and I had to get an EL chain tensioner. Also good idea to replace the timing gears when you do the chain and guides. If it is anything like mine you will have heaps of stuff in the sump and maybe in the oil pickup as well. Good luck getting it all back on the road.
14-01-2005, 05:20 PM | #4 | ||
geez thats bad...hope mine doesnt do that any time soon?
So whats comes after this???
1994 EF XR6 |
14-01-2005, 05:30 PM | #5 | ||
Last warning
i new to replace:
timing gear. timing case harmonic balancer head rocker gear and i need to clean out the sump i think that sums it up :P
14-01-2005, 05:53 PM | #6 | ||
Two > One
Just pull the engine. Its less work, honistly. I would also be pulling the oil pump out and cleaning all the oil galeries. Way to much work. Just pull the motor, replace it with a low KM El/au motor. Then u can play with your EF head for as long as you like ;)
-excuse the bad english, this was typed ion 3sec bursts, damn boss watching me.
14-01-2005, 06:01 PM | #7 | ||
Last warning
if an AU engine was easier to install.. i'd consider it.
EL engine just doesn't do much for me since its basically what i have and i have no idea what its like. atleast if i replace what i plan too.. it'll be all good
14-01-2005, 06:25 PM | #8 | ||
windsor user
nasty lookin stuff there john, pics tell a thousand words!
14-01-2005, 06:38 PM | #9 | ||
E-Series Owners Club
Hmmm, interesting...
I'd want to see it up close, but it looks like maybe the bottom half of the guide snapped, allowing the chain to thrash around a bit (breaking a few things in the process) and making it skip some teeth. That's the only thing i can think of... |
14-01-2005, 07:28 PM | #10 | ||
GT4.
WOw!
Hope it all comes together again soon john! |
14-01-2005, 09:35 PM | #11 | ||
You really did do a great job of it John! You'll have to keep the parts as a talking point for sure!
I bought a new timing cover for the EA engine from Ford and it set me back about $175! They aren't cheap, but for peace of mind I thought that it was worth it. Apparently they are an updated version to stop the leaks they are prone to.
2003 Narooma Blue BA XR6 5spd Manual. Pacemaker 4490 Extractors 2.5" Exhaust High Flow Cat SS Inductions "Growler" CAI Underdrive Pulley Mal Wood H/D Clutch Custom Tune 18" XHP Sabre's 12" Kicker Sub 169.2 rwkw
14-01-2005, 10:33 PM | #12 | |||
i would never buy one new, second hand is fine, just make sure its not cracked!!! |
14-01-2005, 11:27 PM | #13 | ||
There's already a timing case lined up (s/h).
So still need a new balancer, timing kit, gaskets, etc. and then it'll be right to go back together ;) |
14-01-2005, 11:42 PM | #14 | |||
ive got a spare timing cog if you want that. and a new EF ballancer, if you give me an AU one ill swap! |
14-01-2005, 11:56 PM | #15 | ||
Well, we'll be buying a full timing kit. (well, john will be. i'll just watch :P lol) So that will have timing gears, guides, chain and all in it.
We'll probably just get a changeover balancer (coz i don't have an au one to give you - Sorry! :( ) |
15-01-2005, 02:58 PM | #16 | ||
I just remembered I have EF rocker gear from the taxi John, you know how well that car went from the demo I gave you guys lol. Let me know if you want any of it, it's clean as a whistle but you'd want to change the lifters.
I'll say it again though after looking at the pics, I'd be looking at replacing the motor. I would have had one for you if I raised my hand and bidded for the EF Fairmont at auctions that went for $500!! That car was mint but I was too slow with my number thing. Sundeep |
15-01-2005, 05:01 PM | #17 | ||
Two > One
$500 for EF fairmont! dang, id buy it and take it to a wrecker and say $800
15-01-2005, 06:52 PM | #18 | ||
Last warning
Damn... cheap EF :o
but i got rockers :P i'd rather not change motor.. lets just hope its all good once together again ;)
