04-07-2005, 10:58 AM | #1 | ||
likes falcon's
any tips wen undoing locktighted items?
www.carhubsales.com.au |
04-07-2005, 11:12 AM | #2 | ||
Prepsol/WD40, and a lot of force.
1998 Ford Fairlane - 4.0L
18x8 RJR rims - Tinted - King Suspension - 2.5" D&T Cat Back Exhaust |
04-07-2005, 01:53 PM | #3 | ||
hibernating
if you're talking about tailshaft bolts i've got a plan of attack.. i remember how i did it last time though they wouldnt of been as tight as they are now. i used my torque wrench as a breaker bar on the 18mm bolts and that got them undone quite easily. the torque wrench is bigger than your breaker bar and yeah i that should get it... hopefully. i remember i was having trouble using a socket wrench thing.. and then the torque wrench got them really easily.
04-07-2005, 03:37 PM | #4 | ||
dont know what its called but there is a device that you can put a socket on the end of , and the other end you belt with a hammer which force the bolt undone.
someone should know what they are called. cant think of it at the moment. impact driver maybe????? |
04-07-2005, 03:51 PM | #5 | ||
Smash the Boost
using a torque wrench as a breaker bar will ruin its calibration in a real hurry
davway i think you are correct in saying that tool is a impact driver another way is to heat the bolt with a oxy torch then go at it with a breaker bar and impact socket
2023 Hyundai Palisade 1971 Fairmont Sedan 1974 SWB F100 Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
04-07-2005, 04:10 PM | #6 | ||
Locktite sucks!!! I couldn't even get my diff plage bolts undone with a 3/4 rattle gun!
2003 Narooma Blue BA XR6 5spd Manual. Pacemaker 4490 Extractors 2.5" Exhaust High Flow Cat SS Inductions "Growler" CAI Underdrive Pulley Mal Wood H/D Clutch Custom Tune 18" XHP Sabre's 12" Kicker Sub 169.2 rwkw
04-07-2005, 04:29 PM | #7 | |||
dont use a torque wrench as a breaker bar if you can avoid it. Go to a hardware store and grab 18" of 1" steam pipe, put that over the end of a spanner and hang off it - I have never found a bolt that wont budge.
04-07-2005, 04:29 PM | #8 | ||
V8 Turbo Hoon
heat it up, i do the same thing to undo similar things at work. but dont go crazy with the heat.
04-07-2005, 04:36 PM | #9 | ||
hibernating
thats ok i dont want to use this torque wrench as a torque wrench anyway.. its one of the cheaper ones and isnt very accurate at all. i used it on my rocker gear and one of the rocker gear bolt heads snapped off, and i used it on my tailshaft bolts and they ended up coming loose lol. so it works better as a breaker bar
04-07-2005, 06:12 PM | #10 | ||
what bolt are you trying to undo?
04-07-2005, 06:14 PM | #11 | ||
hibernating
tailshaft bolts
04-07-2005, 06:54 PM | #12 | ||
BF F6, APV SR3900
yea impact wrench will work...
otherwise get a long socket handle.. torque wrenches have a tendency to themselves when put in situation...
Santo White APV SR3900 [WIZZRD] (Click Here) [/COLOR] Daily: 2006 Red BF F6 Typhoon Bluepower enhanced. |
04-07-2005, 06:57 PM | #13 | ||
GT
mild heat melts locktight it is a well known trade secret
04-07-2005, 07:07 PM | #14 | ||
likes falcon's
ye, a pole works empty steel pipe but ye just gotta find one, we were using a 30odd cm braker bar and bastard wouldnt budge...
04-07-2005, 07:21 PM | #15 | |||
Bad Music and Litre Bikes
WeetBix are a must before anything involving strength!
no wonder your torque wrench doesnt work too well neb, using them backwards hurts them really badly. I havent even used mine yet.. i need some 1/2inch drive sockets good excuse to go shopping i think!
XY Wagon - NAKED! Quote:
05-07-2005, 09:09 AM | #16 | ||
likes falcon's
we got them off, torque wrench and uni joint
05-07-2005, 06:56 PM | #17 | |||
pffft, rattle gun.
06-07-2005, 02:13 AM | #18 | ||
burn out king
i had to get some rounded off ones un done with an angle grinder ;)
