Old 23-07-2005, 06:51 PM   #1
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Thumbs down Geezus , Ford Problem
My Tx5 Broke down something shocking today in cranbourne on Thompsons Road. Was Driving Back from Frankston and the car was in D and all of a sudden there was no acceleration , But the Car was still on and it was revving , I Knew i Had a Automatic Transmission Problem so I Pulled over and Let it sit , then moved and it was good, but then , at Thompsons Road , It Happened again , so i Stopped and Checked under the Bonnet to see water ****ing out of a heater Hose and the Radiator was Bone Dry , So Im Wondering Would that affect the Transmission More ?
Im Thinking of Ditching it For Something in the E-Series Range , So Ill just cash in my rego and save a bit of cash , cos this car is starting to Break down in stages , The Interior is Great , and the Body is Strait with a bit of Crows Feet in the Paint work , but id rather something bigger anyway , So If you know of any Eseries Cars Selling Cheap , PM Me
Cheers Red :
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2005, 09:13 AM   #2
TX5 GT
Sold one of the Telstars
My Advice would be to get a AT or AV TX5 (87-92) because they are much bigger than what you have, plus the Ghia has everything plus more. The fuel economy is great, and i have 2 of them (a Ghia and a GT) The Ghia i have has done over 320,XXXkms and not a thing wrong with it, *touchwood* and we have owned it since its had 130,XXXkms and only ever replaced a Water Pump.
89 626 GT-TURBO
CAI - SUNROOF - ADJUSTABLE SUSPENSION - SOUND SYSTEM - CRONOS FRONT END - 4SPEED AUTO - 15PSI - EXHAUST - FRONT MOUNT COOLER - HEAVY DUTY BANDS - TORSEN LSD - DYNOED AT 145KW ATW @ 6000RPM everything after 4 speed auto is a typo
TX5 GT is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2005, 09:18 AM   #3
TX5 GT
This looks like a good one
http://www.carsales.com.au/pls/carsales/!cs_content.private_vehicle?vehicle_id=2253883&cur rent_rec=5&used_rec=11&total_rec=16&sort_type=&tot al_rec=16&sort_type=&make_id=6&model_id=200&state_ id=7&search_distance=25
89 626 GT-TURBO
Old 25-07-2005, 10:37 AM   #4
Kryton
Kryton's Avatar
yes it will affect your transmission.
the transmission oil runs through a part of the radiator to cool itself. if you have no way of cooling it (no water) it will get too hot and too thin.
basically if the oil is too hot, its like having no oil at all in the tranny......it just doesnt work at all.
fix the water leak and your tranny will be fine.
Kryton is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2005, 10:49 AM   #5
The MaDDeSTMaN
No longer driving a Ford.
The MaDDeSTMaN's Avatar
There are a few cheap e series Falcons in the For sale section ( http://www.fordforums.com.au/forumdisplay.php?f=41 ), if that's what you want to get...
For example:
http://www.fordforums.com.au/showthread.php?t=15671 89 EA Fairmont duel fuel $800
http://www.fordforums.com.au/showthread.php?t=15058 ea falcon s only requires windscreen for RWC $1300
There are others, but those are the cheapest I found on the first page, and no doubt there are others on the other pages in that section...
Originally Posted by russellw
For those who get their jollies attacking other people let me remind you that we will not tolerate this here. If you want to do that then I am sure your presence would be welcomed elsewhere.
The MaDDeSTMaN is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2005, 11:23 AM   #6
Kryton
Kryton's Avatar
go down to both the auctions, youll find something there.
Old 25-07-2005, 10:18 PM   #7
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
My Car stopped today and wouldnt go into Gear , i Put it in Drive and It Just Sits theere and revs , tried 1 2 and R and its the same but if the car is rocked and then Just put in D it goes for about 1-200 Meters and then slips out of Gear and s Up
AU2PWR
