Old 24-07-2005, 11:10 AM   #1
Mike Gayner
Mike Gayner's Avatar
Default Any TV Tuner card experts here? Need help
Howdy folks, just got myself a TV tuner card. It's just a cheapo $97 DSE card and I have a couple of Q's. First off, I can't get the remote to work. I don't know what to do, there's no drivers and the computer just doesn't seem to give a toss that the thing is even plugged in. Second, I'm using software called TVR, and when I record I can't seem to record the sound. Any ideas?
Mike Gayner is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2005, 11:14 AM   #2
bugger1
69 ZB
Default tv tuner
Only thing i can recommend without knowing your computer specs is doing a internet search for drivers for your card,sounds like you dont have any installed
Cheers bugger1
bugger1 is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2005, 11:26 AM   #3
Mike Gayner
I have installed the drivers that came on the CD. The card plays fine and records video well, just doesn't record sound. The remote thing is annoying but not major, I'm usually close enough to change channels with a mouse.
Old 24-07-2005, 11:36 AM   #4
bugger1
69 ZB
Must have an issue reconizing your sound card im speaking the obvious i suppose,can you put it into another machine to see if it works there? try updating your sound drivers
Old 24-07-2005, 12:13 PM   #5
Mike Gayner
Ah I sussed out the sound problem, I moved the audio out cable (tuner card -> sound card) into the Mic port, seems it won't record sound through the Line In port for some reason. Now it's only the remote issue to sort.
Old 24-07-2005, 01:08 PM   #6
megsy
Undergraduate EB Operator
megsy's Avatar
ur sound problem is a platform one not a software one,
in windows u go to ur usual volume controls then options-->properties then click recording and ok
that gives you a heap of new controls including where your ment to be recording from, also change back to line in as you will get much better sound quality from there
Simon
04 BA Xr6 ... now with carpark dints
megsy is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2005, 05:56 PM   #7
BlackLS
On my other computer I had the same problem, on the software cd there should be a seperate remote program that loads to the system tray.
Does the IR sensor plug into the TV card?
