Old 03-08-2005, 11:54 AM   #1
1TUFEA
MONTY is Alive !
1TUFEA's Avatar
Question oh my god !
well i am right now changing my spark plugs and when i undid plug number 4 i found oil around in what does this mean ?
Originally Posted by bindi
I may be a grumpy redheaded bigbutted chick.
1988 Ford Fairmont EA Series 1
MODS: Hurricane Extractors, Red dash light, Fake Xenon Lights, Mpfi Conversion, Dumpage, 17" ANZ Mayhems (Chrome)
TO COME: 5 speed trans, 4.11 LSD, Carputer, Stage 2 cam, Major Head Work . :
1TUFEA is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2005, 11:56 AM   #2
niko
likes falcon's
niko's Avatar
in the hole? were mr spark lives? could be the possibility that your rocker cover gasket is leaking.
www.carhubsales.com.au
Old 03-08-2005, 12:01 PM   #3
CruizinEB
if it is the rocker cover gasket, There eszy to replace, the cork ones are $30+But dont last so get a rubber/plastic one For around $60+ from Repco And solve this problem for good..
CruizinEB is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2005, 12:18 PM   #4
1TUFEA
MONTY is Alive !
1TUFEA's Avatar
My god damned car is giving me the s again! Sometimes I go to start it, and it nearly fires, but then doesn't. If I try to start it again, it just cranks, but doesn't fire. I checked my leads with a multimeter, they are fine. The plugs are a 10,000kms old & look like the cars been running a little rich but I will replace them tomorrow. Air filter (stocky) could do with replacing as well. Once the car does start (usually with accelerator pushed to the floor) it obviously lets out a hell of a fuel smell.
Any ideas what can be causing this starting problem?? Could it be the plugs? Is it even possible for ECU cars to flood when they are cranked over just the once? Anything else I should look for that might be causing the problem?
Old 03-08-2005, 12:26 PM   #5
Heeno
Formally knowen as EBus
Heeno's Avatar
i'd say that spark plug isn't firing right, if i have a plug like that on my moto, its because im running my mix to rich, not firing right or theres a problem with my piston ring.
EDIT: also wouldn't hurt to check/replace your air filter, its probably restricting airflow making you run rich.
Car: :evilking: 91 EB Fairmont 3.9L :evilking:
Changes: 5 spd manual
Extractors, 2.5in exhaust
AMG Quake 17's w/ maxxis rubba
Lovelle superlows
Cheap a55 Pod Filter
Bike: CR250R 05 :evil3:
Heeno is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2005, 03:10 PM   #6
Simmo
White Lightning
Simmo's Avatar
Originally Posted by niko
in the hole? where mr spark lives?
BWAHAHA, quoted!
Simmo is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2005, 03:13 PM   #7
Shonky
my other ride is the bus.
Shonky's Avatar
1994 ED Fairmont Ghia (Retired to the shed...)
1999 AU Futura
+ Lots of Land Rovers
Originally Posted by Sourbastard
Edelbrock.... not Peter Brock. Theres a world of difference. For a start my heads have much less gum tree in them.
Shonky is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2005, 03:19 PM   #8
ilsautomotive
Former E-Series Member
Could be your O2 sensor? Just a guess...
Old 03-08-2005, 06:56 PM   #9
Brent-EA Ghia
Brent-EA Ghia's Avatar
Could also be your injectors leaking after the cars turned off, so if the plugs don't fix the problem and its got good spark i'd be looking at getting the injectors done.
Proud Owner of 06' TTG
Brent-EA Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2005, 12:07 PM   #10
TUFED6
TUFED6's Avatar
Thats a ****er! Spark plugs will now be referred to as Mr spark.
- John
TUFED6 is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2005, 06:44 PM   #11
DivaChick
had a simlar prob with my eb. was the injectors leaking down over night.
