Old 21-01-2005, 08:30 AM   #1
Bass Crazy
Default El Belt Change, Any tips?
Hey guys,
I will be changing the engine belt on the EL tonight. I have not even loked at the thing yet. Does anyone have any tips,or can give me a rough idea of what to expect to speed things up a little.
Oh the radiator is out for cleaning already.
Any info would be great.
Thanks guys!!
Bass Crazy is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2005, 09:11 AM   #2
EFFalcon
Last warning
EFFalcon's Avatar
Its too easy
put it over everything except the water pump, put a breaker bar into the belt tensioner and pull it to release the tension and slip it over the water pump pully.
(there should be a diagram on the underside of the bonnet on how to route it around everything)
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 21-01-2005, 09:19 AM   #3
Stevo
Yup, what John said. If you dont have a breaker bar, slip a shifter in there, with a bit of pipe over the handle. When you put the new one on, make sure its lined up ok. Sometimes if you have trouble lining it up, cranking the engine over a few turns (not starting it, but just about), will sometimes do the job.
Dont run, or rev the car hard with the belt not lined up, otherwise it will probably end in a big tangle, but generally, they line up pretty easy.
steve
Stevo is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2005, 11:25 AM   #4
Bass Crazy
Ahh so its just a spring loaded tension.. and no bolts.
Sweet!!
Thanks for that fellas.
Old 21-01-2005, 12:00 PM   #5
neb
hibernating
neb's Avatar
oh what spring loaded tension... us ea-ed drivers are missing out :-/
neb is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2005, 06:39 PM   #6
Psycho Chicken
Psycho Chicken's Avatar
uhhh Simon has an EL?
Shit I need to keep up with things.
Old 21-01-2005, 06:46 PM   #7
Danny
GT4.
Danny's Avatar
Dont forget to take off the black belt ancillaries cover from the front of the engine. Take the lid off the power steering resivoir, undo the 12 (or 13mm?) nut from the other side of the cover and pull it straight off, that will give you room to do ya thing ;)
Easy as Anna Nicole!
Old 21-01-2005, 09:22 PM   #8
Stevo
*looks under his desk*, "dont listen to him Anna, i know he is a meany..:.
Old 21-01-2005, 09:43 PM   #9
Kenaz
Kenaz's Avatar
I think his old man does.
Kenaz is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2005, 09:59 PM   #10
svo347
AFF's 1st DM.......
svo347's Avatar
ED's do have the auto tensioner!!
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 21-01-2005, 11:42 PM   #11
DentEd XR8
DentEd XR8's Avatar
Not on the 6 dude, still the same as an EA
Ed
DentEd XR8 is offline   Reply With Quote Multi-Quote with this Post
