Old 11-08-2005, 12:35 PM   #1
Heeno
Formally knowen as EBus
Heeno's Avatar
Default where can i get cold air induction??
hi all,
where in brissy can i go to get a cold air induction setup?? i can get a the filter from repco/supercheap (k&n of course), but where can i get a decent sized snorkel? and some piping so i don't have to run the dodge plastic pipe. or if there's a place that sells a complete setup that would be great
cheers all
Car: :evilking: 91 EB Fairmont 3.9L :evilking:
Changes: 5 spd manual
Extractors, 2.5in exhaust
AMG Quake 17's w/ maxxis rubba
Lovelle superlows
Cheap a55 Pod Filter
Bike: CR250R 05 :evil3:
Heeno is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2005, 12:58 PM   #2
gozza
gozza's Avatar
i'm lookin for an elbow mandrel bent pipe for my pod too
gozza is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2005, 12:59 PM   #3
gozza
gozza's Avatar
i took out the panel filter housing and have the cover with the snorkel covering it....would it be better to just have the pod exsposed...was just thinkin along the lines that the cover might keep some heat out...
Old 11-08-2005, 01:00 PM   #4
stockstandard
Snorkel from ford
Can get intake pipes made up at most exhaust places
Originally Posted by casper
Old 11-08-2005, 01:06 PM   #5
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
go to bunnings and buy 90mm pvc piping and the elbow bends you need. then fibreglass over the whole lot it works out heaps cheaper and then u can paint it or what ever. fibreglass has better heat reflection properties than most metals.
BLUEPOWER RACING DEVELOPMENTS
Strive for perfection in everything we do. Take the best that exists and make it better.
When it does not exist, design it. Accept nothing nearly right or good enough.
-[BLKPHN] (VIC) PLATES FOR SALE $495.00-
BLKPHN is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2005, 01:09 PM   #6
gozza
gozza's Avatar
ats the easiest way to make a heatsheild?
Old 11-08-2005, 01:38 PM   #7
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
get a peice of alluminuim, make a template out of cardboard, to fit where you wan it to gao and then cut ti out using a metal blade on a jigsaw. file off the rough edges and make or get some brakes out of the left over alluminium and away you go it easly done. but i still reckon that going to bunnings and using 90mm PVC is the best way to go, you can also get the rubber conections and hose clamps to fit the throttle body.
Old 11-08-2005, 01:44 PM   #8
gozza
gozza's Avatar
yeah the rubber fittings for the throttle body was my concern
"make or get some brakes out of the left over alluminium and away you go it easly done"
brakes????
wat about the stamped plated metal for a heat sheild??
Old 11-08-2005, 01:47 PM   #9
Heeno
Heeno's Avatar
ah sweet as, thanks for the info, i think i'll go the bunnings way an aluminium heat shield, my mates got some fibreglass stuff, like car bog but for fibreglass...would that be alright??
Lovelle superlows
Old 11-08-2005, 01:50 PM   #10
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
the rubber fittings were like $10 it fitts the throttle body and the 90mm PVC, the heat sheild can be mounted to the bolts for the air box or just make new ones but be sure you don't cut in to the chassis.
you mean checker plate? it comes in alluminium and steel. can get from bunning to yeah you can use that.
i actually cut a hole under where my air box used to be and made the pvc pipe go through there and down just behind the front bar good cold air down there.
Old 11-08-2005, 01:53 PM   #11
gozza
gozza's Avatar
aiight so i need a 90 degree elobow pipe
a smaller sraight one
some rubber fitters for the throttle body
yeah i was talkin bout checker plate haha get some of that cut out the shape and a hole for the pipe
bolt the er on and i'm ready to go.....yeah mayaswell go the piping underneath the pod for cold air
Old 11-08-2005, 02:04 PM   #12
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
cold air works a treat i used 2x 90deg bends and one 22deg. to tilt it towards the front bar. i didn't bother with the pod filter inside the engine bay evan with a heat sheild it will still get hot and there is not much moving air inside the corner people put it in. the pvc should be coverded in fibreglass not bog because of the great het deflection properties. i went and spent $50 on fibreglass stuff and i think i could make a whole boat, i didn't realise how little i needed. the only thing i am carefull of is whel it rains the pod will get wet. and thats not good. so i keep the stock bendy pipe to the stock airbox in my boot and when it looks like rain i swap the pod onto that. i would have some pics to show u but im not on my own computer. send us a pm with ur email and i'll send u some pics of the set up if you would like.
Old 11-08-2005, 02:09 PM   #13
gozza
gozza's Avatar
thnx heaps man
Old 11-08-2005, 02:12 PM   #14
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
thnx heaps man
no Fwurrys i'l send u some pic when i get home damn tafe im overit today, spening more time on good ol' ford forums instead. lol. glad to help mate. :
Old 11-08-2005, 02:13 PM   #15
gozza
gozza's Avatar
haha i know how it it is man i'm at work
