Old 11-08-2005, 01:59 PM   #1
gozza
gozza's Avatar
Default Fitting Thermos??
i want to put some thermos in but i heard u have to get the ef/el ones...
wats the easiest and best way to fit the thermos into an EB
gozza is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2005, 02:02 PM   #2
EA2BA
PM me if you want
EA2BA's Avatar
get ef/el ones, some relays and a thermo switch.
Old 11-08-2005, 02:05 PM   #3
gozza
gozza's Avatar
will if fit straight on or will some cutting need to be done?
Old 11-08-2005, 02:08 PM   #4
EA2BA
PM me if you want
EA2BA's Avatar
remove the clutch fan and shround, you need to make sure you have the little mounting points (i.e. nuts in the top of the radiator), and yes it mounts straight in.
Old 11-08-2005, 02:08 PM   #5
gozza
gozza's Avatar
cheers man
greatly appreciated
Old 11-08-2005, 02:09 PM   #6
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
it fits in no worrys take off the clutch fan and you should b able to fit it straight in. make sure you wire it up properly. Mick (initalD) has had a few problems with his set up and it drains 30amps when they are on. not good. so take time and ground it properly.
BLUEPOWER RACING DEVELOPMENTS
Strive for perfection in everything we do. Take the best that exists and make it better.
When it does not exist, design it. Accept nothing nearly right or good enough.
-[BLKPHN] (VIC) PLATES FOR SALE $495.00-
BLKPHN is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2005, 02:10 PM   #7
ilsautomotive
Former E-Series Member
We really need a tutorial on this. The EF/EL radiator has mounts for the fans but the water pump outlet is a different size on the six cylinders. An EF/EL V8 radiator is suitable for a thermofan conversion on any EA-ED. But to avoid this expense, most people mount the fans using a more imaginative method (cable ties? ).
Old 11-08-2005, 02:12 PM   #8
gozza
gozza's Avatar
i was a little confused cos one of my mates reckoned he had to around and cut some plastic from somewhere
but i'll look into getting a thermo and doing it...ive seen dual ones for an el on ebay
Old 11-08-2005, 02:18 PM   #9
EA2BA
PM me if you want
EA2BA's Avatar
Most aftermarket radiators contain the mounting points without being anything special, the radiator I bought for an EA off e-bay has the mounting points, and the natrad radiator smut had in his car (was there when he got it) had the mounting points as well, and I think John_XR6 had the mount points on his as well.
Old 11-08-2005, 05:31 PM   #10
STOKEB
NOS Induction pssssshhhhh
STOKEB's Avatar
Instead of using those adjustable thermo switches get your self a Honda thermo switch it screws into your thermostat housing no taping is required, The honda thermo switch hasnt got any adjustments on it. Its set to one temp which is close enought to running temp on the falcons. Theres 2 pins on the switch one is grounded and the other runs to the rellay as simple as that.
STOKEB - 3:7 diff gears, 3inch zorst, JMM Race Series Extractors, Custom Bottom end to suit N20, AU DEV 6 Head and Cam, Cold Air Intake, ED XR6 Manual Computer with Flash Tunner, ED XR6 Fuel reg, C10 Auto, 2800stall .
I LiVe My LiFe A bOtTlE aT a TiMe, FoR tHoSe 200 sQuIrTs I fEeL fReE.........pssssssssssssshhhhhhhhhhh
STOKEB is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2005, 05:41 PM   #11
CruizinEB
if was doing to put thermo fans on my EB i would be wored about hiting the radiator and stufing it up
CruizinEB is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2005, 06:22 PM   #12
Damo
There is a tutorial on www.deleted link
Old 11-08-2005, 07:12 PM   #13
NZ
NZ's Avatar
If you really want to keep you ford all ford you can use a capri thermo switch. They run at the falcon running temp. They use a half inch npt thread so they screw into the thermostat housing on the 6's and into the spare port on the heater line on the 8cyl (models without climate)
EF Falcon Sedan 5.0 auto with IRS
"the man that crashs AFF"
Old 12-09-2005, 01:13 PM   #14
XRated
Shoot.
XRated's Avatar
Has anyone else fitted this Capri thermo switch? I need to know everything else I need to get (except for thermos :P).
Can anyone here get retail prices on Ford stock - on the Capri switch?
20V Turbo
