Old 11-08-2005, 04:11 PM   #1
gozza
gozza's Avatar
Default How do you advance the timing
yeah in my eb
gozza is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2005, 04:35 PM   #2
Simmo
White Lightning
Simmo's Avatar
with a timing light. as far as i know you have the timing light going and you turn on the dizzy somewhere with a spanner/socket. and you can see the little TDC line move forward. best to get a mechanic or someone with know how as you could easily crank it way over and ping it nuts off.
Simmo is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2005, 04:52 PM   #3
FordFan86
meow
FordFan86's Avatar
I'd say the best way to do it would be on a dyno? advance it, run it up and listen for pinging and the power difference?
FordFan86 is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2005, 05:14 PM   #4
Simmo
White Lightning
Simmo's Avatar
nah you dont need a dyno really. in 99% of cases the power increase isnt that massive. just crank it up go for a drive to the redline a couple times and listen. mins on about 18 degrees of advance at the moment. ive heard people running up to 20. any more and most cars ping.
Old 12-08-2005, 09:17 AM   #5
gozza
gozza's Avatar
yeah sik cos my eb on paper should be killin my mates but it doesn't....hes got advanced timing...and i use premium or higher so advanced it should be good....new head too....
Old 12-08-2005, 10:35 AM   #6
neb
hibernating
neb's Avatar
make sure you short the self test pins together to get it into the mode to set timing. it's the 2 left pins on the connector under the steering wheel. my method is adjust the timing on the worst fuel that you use... i always use 98 octane so i can run advanced timing.. if you sometimes use standard fuel I would set the timing to work with that.. otherwise when you do use standard fuel it might ping. Basically advance it littles bits and take it for a drive... once it pings you've advanced it too far so put the timing back just a little bit and that should be good. Advanced timing seems to make a BIG difference on these engines so everyone should do it.
neb is offline   Reply With Quote Multi-Quote with this Post
