Old 17-08-2005, 07:28 PM   #1
Street Sleeper
Street Sleeper's Avatar
Question Auto question
I have an EF 94 4.0 auto with 190k on the clock.
Just lately the auto has been behaving a bit strange.
Sometimes (only sometimes) it doesn't seem to matter what gear I lock it in (eg 2nd) it just keeps running up the gears like its in Drive.
At first I thought no problem 'it's just a linkage problem' cause it was going into 4th when I had it locked in 3rd.
But today I dropped back to second (at about 55kmh) and it goes no where (stays in 3rd) and continues on rolling along. I thought thats strange so I come to a roundabout and at a full stop I put it in 1st to see if would hold it. It didn't, it ran all the way back up to 4th as I accelarated while still in the "1" position.So when I stopped at a stop sign I ran it all the way up the rail to the Park position and then back into 1st and only then did the transmission start acting as it is supposed to.
Now apart from the auto doing this, it is fine. It still changes gears smoothly and downshifts when it gets a boot full. I'm thinking it might have something to do with electrics of the system. I know that they will not change down if you going "too fast" but this is not the problem.
I did disconnect the battery about a week ago and I know they take time to learn where they are again, but nothing like this. I followed the workshop manual on how to make the auto learn its settings after changing the battery like I have done previously.
Any ideas on the what the problem might be will be appreciated.
Street Sleeper is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2005, 07:30 PM   #2
FRDGAL
GT-P #0336
FRDGAL's Avatar
Sounds like the Inhibitor switch
2003 FULLY OPTIONED MERCURY SILVER BA GT-P BUILD #336
REVERSE CAMERA - SAT NAV - PIONEER SUB & AMP - SUNROOF - DVD PLAYER - CUSTOM DUAL EXHAUST
~Tuned By Bluepower Racing~
FRDGAL is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2005, 07:42 PM   #3
Street Sleeper
Are they costly/easy to change out ?
Old 17-08-2005, 07:44 PM   #4
FRDGAL
GT-P #0336
FRDGAL's Avatar
We didn't do it ourselves - our mechanic did it so I don't know if it's an easy change but IIRC it was $120 supplied and fitted.
Old 17-08-2005, 07:46 PM   #5
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
That's a good price, I paid $90 for the switch itself. It's not hard to change, 3 small bolts and 2 electrical plugs on the passenger side of the trans.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2005, 07:47 PM   #6
Street Sleeper
So it is external then?
Old 17-08-2005, 08:26 PM   #7
Clarke AV
OzECruisers Treasurer
Clarke AV's Avatar
It s BUGGERD the ks
Clarke AV is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2005, 08:32 PM   #8
Street Sleeper
Like I said Clarke it seems fine apart from the the not holding allocated gear problem. It's had 4 services in them 190k's.
Old 17-08-2005, 08:35 PM   #9
Clarke AV
Clarke AV's Avatar
4 OOOoooooooo
Old 17-08-2005, 08:37 PM   #10
Clarke AV
Clarke AV's Avatar
One service too 40k ye ye NO
Old 17-08-2005, 08:38 PM   #11
Street Sleeper
4 services on the automatic that is.
Old 17-08-2005, 08:40 PM   #12
Street Sleeper
So maybe it did a couple of thousand too much in between services. It's still not what I'd call badly neglected.
Old 17-08-2005, 08:40 PM   #13
Clarke AV
Clarke AV's Avatar
The switch is $110 for a v8 1
Old 17-08-2005, 08:41 PM   #14
Street Sleeper
Thanks
Old 17-08-2005, 08:50 PM   #15
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
Yes the switch is external. 6cyl and V8 switches are the same IIRC. I would say it's the switch, not the trans bieng stuffed. I've seen BTR's last for 400,000km, they don't ALL die at 200k.
Old 17-08-2005, 09:00 PM   #16
Street Sleeper
I'm sooo happy to hear that.
Old 17-08-2005, 09:03 PM   #17
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
haha, I didn't say they all live for 400k either.........
Put a bit of money away, just in case ;)
Old 17-08-2005, 09:15 PM   #18
Clarke AV
Clarke AV's Avatar
me too
Old 17-08-2005, 09:18 PM   #19
Street Sleeper
I'm afraid if I had to change the auto it would be bye-bye EF.
Old 17-08-2005, 09:37 PM   #20
mcflux
mcflux's Avatar
Mine's running fine on 315,000km with no hiccups Expect plenty more life from ya auto ;)
Old 17-08-2005, 09:42 PM   #21
FRDGAL
GT-P #0336
FRDGAL's Avatar
Our EL is a V8 and it was $120 fitted.
Street Sleeper If it's running through gears irratically, kicking back and jumping into neutral etc and so on then it's gotta be the switch playing up.
Old 17-08-2005, 09:45 PM   #22
Walkinshaw
Two > One
Walkinshaw's Avatar
Does that mean im special killing one in 160k, and another in 5000km?
Old 17-08-2005, 09:50 PM   #23
Street Sleeper
Do V8's run the same BTR 4 speed ?
Old 17-08-2005, 10:02 PM   #24
Age182
GMHKLA number plates
Age182's Avatar
yes different bell housing
Currently owned: 1997 Hyundai Excel (the daily)
2009 FG FPV F6 Silhouette Auto
Previously owned:
1994 EF fairmont Ghia 4.0Ltr, AUTO
14.620@93.3mph
2000 Honda S2000
14.73@92mph (stock + no traction)
Age182 is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2005, 12:06 AM   #25
EBII4.L
sorry to say but my 4 speeder is kinder playin up on me too sometimes it doesnt reverse at all and when u put it onto N the car drives forward? i've checked fluid and stuff seem ok what could be the prob??
Old 18-08-2005, 12:34 PM   #26
mcflux
mcflux's Avatar
the input (or output?) shaft is a different length too.
Old 18-08-2005, 02:06 PM   #27
Kenaz
Kenaz's Avatar
I think I paid about $120 to have the inhibitor switch on mine replaced. Apparently it's a common problem on the V8s. When mine went it made the car do all sorts of weird stuff like dropping back to 2nd whilst cruising at 100km/h for no apparent reason :
02 BA XR6 T U R B O
Venom Red, Auto 13.97 @ 101mph
Originally Posted by Wheels Nov 02
It's suave, more subtle, and yet no less stirring. In fact, the boosted Ford is more polished than any big sedan Australia has ever produced. It's just so damn good, it makes the SS feel crude... Ignore the WRX. Forget the E49. Falcon XR6 Turbo is king.
Kenaz is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2005, 03:07 PM   #28
FRDGAL
GT-P #0336
FRDGAL's Avatar
Well well Kenaz, looky what I found:
Originally Posted by Fairmont_Krissy
Now, down to business. If after you drive it for a couple of days it turns out that it was the switch then you owe us beers - or any alcohol will do just fine lol : :P
lol Well I do manage a bottleshop, so I'll see what I can do
Ahheemmmm
