21-08-2005, 11:50 AM | #1 | ||
eec tweaker
Guys,
I was going to have a go at fitting my 1521a today but realised I dont have the spec sheet for the cam!! Can anyone tell me what lift to expect at TDC so I can dial the cam in??? Jason |
21-08-2005, 01:08 PM | #2 | ||
Last warning
According to Cam Cat (downloadable on the wade website somewhere)
36thou @ TDC on exhaust 38thou @ TDC on intake
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
21-08-2005, 01:18 PM | #3 | ||
eec tweaker
Thanks a heap John. Dave did the same thing... i downloaded it but thought it was out of date (it says 2003!)
Now - the timing mark on the EFs.. is that for TDC or IGN (ie: 10 deg BTDC) ? |
21-08-2005, 01:22 PM | #4 | ||
Last warning
Tdc..
21-08-2005, 01:34 PM | #5 | ||
eec tweaker
thats why i thought.. but it looks too far to the right!
cheers.. |
21-08-2005, 01:37 PM | #6 | ||
Last warning
it lines up with the marks under the timing case.
www.deleted link/pics/temptiming.jpg <-- look there to see what i mean.
21-08-2005, 10:58 PM | #7 | ||
eec tweaker
awesome.
got it in and it was already pretty close to spec - 32 though as opposed to 38. got it spot on with the vernier (yes, i tightened the out of the bolts). it idles like a beast! i used the aluminium plate under the ISC trick to stop the hunting, but it still idles rough. i have it on about 1100 so it isnt close to stalling when i put it into drive. havent driven it yet though.. bloody bracks. |
21-08-2005, 11:13 PM | #8 | ||
just curious. what chip are u running?
5 Speed EL Futura 140rwkw last dyno |
21-08-2005, 11:18 PM | #9 | ||
Two > One
Did moving the cam to spec help the idle or make it worse??
and 1100, are you sure this is advisable!!?!?
1978 LTD - 408ci - 11.5@120.6mph - 2004 S4 - 4.2 - M6 - quattro - Last edited by Walkinshaw; 22-08-2005 at 12:34 AM. |
22-08-2005, 09:46 AM | #10 | ||
Last warning
SOunds good jason
is a high stall next on the list?
22-08-2005, 12:45 PM | #11 | ||
dude ive had a 1521a i did the same as what i think you have big is best but untill you get the rev limiter lifted you wont be able to use this cam and the stock diff ratio is even worse id advise you think strongly bout this and go back to the 977b or even the 1636 just trying to help
22-08-2005, 01:53 PM | #12 | ||
Last warning
steven95falc: he has a 3.9 LSD.
22-08-2005, 03:40 PM | #13 | ||
sweet cos im running the stock diff in a 95 ef manual and she was just to geared up and yea the rev limiter gave me the s cos just as it took of she started to bounce.
22-08-2005, 06:11 PM | #14 | ||
Two > One
Try it with 3.23:1 + auto ;)
22-08-2005, 09:18 PM | #15 | ||
eec tweaker
highstall and chiptorque are next. not sure in which order. im thinking 2500 - 2800rpm but im not sure. as most people know i have already ported the out of the head and thrown 3.9s in the rear end.
walki, dont know if it helped because i never ran the car without dialing the cam in. thought i'd go the whole hog this time, even bought myself a dial indicator. it sounds ing awesome. ive never thought my 6 sound would like this! the hunting is completely gone with the ISC mod, well worth doing. |
22-08-2005, 09:19 PM | #16 | ||
Last warning
get chiptorque first jason
and get a JMM 3000 highstall!
22-08-2005, 09:25 PM | #17 | ||
eec tweaker
you dont think 3000 is too high? JMM are too expensive...
i need to ring chiptorque.. |
22-08-2005, 10:07 PM | #18 | ||
GMHKLA number plates
are you changin the springs too iv been looking at there 1632 i think its 198 and 206 @.50 but i lik the looks of that 1521a
Currently owned: 1997 Hyundai Excel (the daily) 2009 FG FPV F6 Silhouette Auto Previously owned: 1994 EF fairmont Ghia 4.0Ltr, AUTO 14.620@93.3mph 2000 Honda S2000 14.73@92mph (stock + no traction) |
22-08-2005, 10:21 PM | #19 | ||
Last warning
to get the most out of a big cam like a 1521a, you really need to have either a manual, or a highstalled auto, both with some decent diff gears.
22-08-2005, 10:28 PM | #20 | ||
jase, how does it go now with the new cam? From reading the forums, it seems there are mixed opinions on this cam profile. Of course it will go better with the chip but how is it at the moment?
22-08-2005, 10:34 PM | #21 | ||
Last warning
i think the biggest issue is that Jason can't drive his car too much.
there are a few legality problems for now
23-08-2005, 08:41 AM | #22 | |||
23-08-2005, 10:58 AM | #23 | ||
Two > One
The rev limiter isnt really the issue 5750 is plenty of revs. Saying that Stockstandard pulls his to 6300, with the shift light @ 6000.
The main reson you need a chip is to correct the MAP signal. A cam with 217deg@50 will have a serious impact on the vacuum readings within the manafold and thus due to the MAP based load tables, this will throw out the fuel and ignition timing.
23-08-2005, 11:20 AM | #24 | ||||
Shift light is fixed now and flashes at ~5700.
23-08-2005, 11:39 AM | #25 | ||
hibernating
mmm high revs... my rev limiter kicks in at 5200... not so fun, good for my engine i guess, probably doesn't really need to rev any higher than that
23-08-2005, 01:32 PM | #26 | |||
23-08-2005, 03:13 PM | #27 | ||||
23-08-2005, 04:15 PM | #28 | ||
Two > One
Was it the speed or rev limiter??
