Old 21-08-2005, 03:05 PM   #1
InitialD
Low and Loud
InitialD's Avatar
Default Pop! pop!
After my terrible performace at heathcote yesterday, Driving home I noticed that my car made a few "pop" sounds thru the airbox like if the timing was out. Today I had the timing checked and its fine.
I also noticed that my runs were getting .1 of a second slower each go AND the temp on the guage was getting higher ever run I did by the end of the run.
This seems to me to be a timing issue but the timing is correct? Could the dizzy itself be flogged? The car also doesnt want to start alot and backfires or "pops" through the airbox. It also has a rough'ish idle then normal.
its got New Leads, plugs, coil, dizzy cap, rotor button, injectors, fuel filter, fuel reg, fuel pump.
So far Im thinking the Hall effect sensor? or something other in the Dizzy?
Old 21-08-2005, 07:00 PM   #2
LUXO_8
windsor user
might have something to do with the 9" diff???
Old 21-08-2005, 07:08 PM   #3
NZ
NZ's Avatar
Are you checking the timing in self test mode and how confident are you that the harmonic balancer is reading true. Those are the 2 most common causes of incorrect timing when it is checked.
EF Falcon Sedan 5.0 auto with IRS
"the man that crashs AFF"
Old 21-08-2005, 07:18 PM   #4
TIKFD6
Number 5 is alive!
TIKFD6's Avatar
How bad is your dizzy?
Kerry
Tickford wings are for Tickford cars!
"Experimental Racer" #6
1994 Gunmetal XG XR6 1997-1999
[B][COLOR=Red] 1994 Le Mans Red ED
2008 MA XR5 Mondeo
2015 VOLVO V60 T6 R-DESIGN-POLESTAR Enhanced
TIKFD6 is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2005, 11:42 PM   #5
InitialD
Low and Loud
InitialD's Avatar
Timing was checked as I always do, In diag mode and the harmonic balancer is spankin new ;)
The timing is spot on karl
The reason im thinking dizzy is EVERYTHING else in the ignition/fuel system has been changed. The motor has a roughish idle when its running anyway (shakes sorta like a worn enginemount but it isnt) and the PCV valve has made a nice indentation into the underbonnet felt.
what does the Hall effect sensor do? would that cause my dizzy to be acting wierd?
Old 23-08-2005, 01:22 PM   #6
RavenLS1
you can buy a whole new dizzy from bursons for 95 bucks change over and it will come with new hall sensor and tfi and rotor and cap.
RavenLS1 is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2005, 01:26 PM   #7
neb
hibernating
neb's Avatar
Yeah that does sound like something to do with timing. I've still got the dizzy from my old engine if you would like to purchase it from me :P
neb is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2005, 03:55 PM   #8
InitialD
Low and Loud
InitialD's Avatar
PSI wagon - from all Burson stores? Thats ALOT cheaper then buying all the parts themselves.
Ben - if it WORKS ill give you $10 off the seats :P
I just pulled all the intake stuff off, and discovered that the "hall effect sensor" has gone white with ALOT of white burn marks around it (well looks like that to me). Also The Dizzy cap spacer that goes under the rotor button, it had alot of fine metal shaving under it.
im getting its bad?
Old 23-08-2005, 05:09 PM   #9
RavenLS1
well the one in moorabin quoted me that but it is change over and every electrical component on it is brand new.I was spewing i only found this out last week after i paid for a new tfi module from ford for 135bucks i got ripped big time but not to worry.
Old 23-08-2005, 05:23 PM   #10
neb
hibernating
neb's Avatar
lol $10... I think I'll keep it as a spare, I'm sure mine will stuff up eventually.. lol
Old 27-08-2005, 07:38 PM   #11
RavenLS1
Hey initial d did you end up fixing the problem?
Old 27-08-2005, 07:43 PM   #12
svo347
AFF's 1st DM.......
svo347's Avatar
exhaust/inlet manifold leak?
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 27-08-2005, 09:06 PM   #13
MustangNicko
MustangNicko's Avatar
Told ya hall effect sensor aaaaaages ago :P
MustangNicko is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2005, 09:16 PM   #14
InitialD
Low and Loud
InitialD's Avatar
Yes I did, replaced the Dizzy, TFI and the air temp sensor
