Old 22-08-2005, 11:46 PM   #1
EASPRINT
FPV GT-P 335!
EASPRINT's Avatar
Default SLOWEA...needs surgery.
Well guys, I removed rocker cover tonight...and I'm still tryin to find what this knocking noise is?. I'm hoping its just a lifter that's let go, but at the moment I can't see one thats not pumping up. So...i will try changing the whole rocker rack over...and if that doesn't fix....The head will have to come off. Either way, I think she'll be out of action for a while!. It needs an Auto...and the 9 inch fitted. And if it does turn out to be a major engine problem.....I'm gonna go bigger and better...and really chase some big numbers next time! :
Current rides - 2013 FPV GT-E MK2 & 2010 FPV F6-E
Tuned by Michael J's & Son.
EASPRINT is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2005, 11:51 PM   #2
EFFalcon
Last warning
EFFalcon's Avatar
bugger... was hoping it would be a simple fix.
time will tell i guess.
keep us all updated!
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 22-08-2005, 11:53 PM   #3
dansedgli
dansedgli's Avatar
I hope its nothing too major mate.
Hope to see it back out soon.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2005, 11:53 PM   #4
InitialD
Low and Loud
InitialD's Avatar
ahh man that aint good :( I was hoping as you said earlier today it was just a lifter.
Old 22-08-2005, 11:55 PM   #5
neb
hibernating
neb's Avatar
hopefully nothing major.. well if it is as you said you can just build it up better and stronger anyway
neb is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2005, 11:56 PM   #6
EASPRINT
FPV GT-P 335!
EASPRINT's Avatar
At least i broke it having fun!.....that what we build these sort of cars for!
Old 23-08-2005, 12:00 AM   #7
John_LS1
you see, the problem is that woodgrain shifter surround needs to be sold to me :P
but seriously yeah that is dissapointing, hopefully it will lead to better things like you said
Old 23-08-2005, 12:27 AM   #8
InitialD
Low and Loud
InitialD's Avatar
LOL I have to agree there :P
Old 23-08-2005, 12:06 PM   #9
MRD-Ben
Life begins @30psi
Hey Slowea, sorry to hear bout that, before you go changing anything just try unplugging the injector plugs or spark plug leads one at a time, what this does is takes the load off that cylinder, if the noise goes away its hurt a bearing in the bottom end. Its the easiest way to check this stuff without pulling an engine out. Hope this helps
Cheers MRD
MRD-Ben is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2005, 12:12 PM   #10
FordFan86
meow
FordFan86's Avatar
cough *big ends* cough
FordFan86 is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2005, 04:27 PM   #11
brenx
brenx's Avatar
Hopefully it's something obvious and simple thats been over looked. Engine rebuilds are no fun. I'm putting mine off for as long as I can :P
74 XB Fairmont (street car) 11.07@123.02mph. 08 LV Ford Focus XR5 (daily).
Tuned by Hallam Performance
brenx is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2005, 05:15 PM   #12
EASPRINT
FPV GT-P 335!
EASPRINT's Avatar
Cheers MRD
Thanks for the advice :thebirds: ...I will give it a go.
Old 23-08-2005, 05:47 PM   #13
BlOWN-EA
BlOWN-EA's Avatar
when is the knock sound there?
i have fixed many falcons with engine knocks and lifter noise
just cause your lifters are pumping up doesnt mean anything,
pull off your whole valve train and check rockers for side way
movment and check rocker dowels for wear, all ok then get an
air blower and blow out every single oil gallery in the valve train
still noisey and lifters repalced then i got more tips for ya. just
use the flat head stethascope trick.
BlOWN-EA is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2005, 06:45 PM   #14
EFFalcon
Last warning
EFFalcon's Avatar
to me, the sound was a bit deeper then just a lifter.
there is a video of EASPRINTS car at the drags where u can hear the noise.
hxxp://www.deleted link/pics/cruises...te7/slowea.avi
Old 23-08-2005, 07:08 PM   #15
Gunns
Gunns's Avatar
Sorry to hear Dave. It sounded a bit like a "gudgen" (spelling) pin to me but I was hoping it was just a lifter.
Gunns is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2005, 07:14 PM   #16
AUII_Forte
AUII_Forte's Avatar
Sounds a lot like a dead lifter to me. It's too sharp to be a bottom end problem. Could be a pin or a broken piston or something though I spose.
2003 Narooma Blue BA XR6 5spd Manual.
Pacemaker 4490 Extractors
2.5" Exhaust
High Flow Cat
SS Inductions "Growler" CAI
Underdrive Pulley
Mal Wood H/D Clutch
Custom Tune
18" XHP Sabre's
12" Kicker Sub
169.2 rwkw
AUII_Forte is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2005, 08:17 PM   #17
Grechie
Grechie's Avatar
holy crap, thats the exact sound i had wen the 2 bolts in the conrod holding piston number 1 dropped out in my 3.9CFI in geelong!!!!
2015 FGX XR8 - 557rwkw on E85
KPM Street Fighter
PCMTec
Michelin Pilot Sport Cup 2 - 255/35/19 - 275/35/19
Shockworks Coilovers
PITLANE AUTOMOTIVE & PERFORMANCE
Grechie is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2005, 08:24 PM   #18
LUXO_8
windsor user
hope you can find the problem dave.
if not, as you said.....bigger and better
Old 23-08-2005, 08:26 PM   #19
EFFalcon
Last warning
EFFalcon's Avatar
i think the sound is your engine asking for a bigger turbo
Old 23-08-2005, 08:27 PM   #20
Stevo
Dude, check your pod filter.
Id say you have sucked up a skyline
Heritage Green EL Ghia
Black AUII XR8 Ute
Stevo is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2005, 08:41 PM   #21
EASPRINT
FPV GT-P 335!
EASPRINT's Avatar
Yeah...i think i can see one stuck in there :voldar02:
Old 23-08-2005, 08:46 PM   #22
t2te50
Broken damper spring?
t2te50 is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2005, 11:13 PM   #23
sphell
sphell's Avatar
yeah that's what I was going to say, maybe one of the springs is cracked. does the knock go up and down with the revs?
Old 23-08-2005, 11:20 PM   #24
EFFalcon
Last warning
EFFalcon's Avatar
sure does.
Old 23-08-2005, 11:23 PM   #25
sphell
sphell's Avatar
yeah i just listened to that video of yours. sounds a bit loud for a spring or lifter :(
Old 24-08-2005, 12:34 AM   #26
EASPRINT
FPV GT-P 335!
EASPRINT's Avatar
Ah well....i got a couple of years of thrashing out of it :voldar02: full blown drag car...here we come!
Old 24-08-2005, 01:54 AM   #27
THORNSPAWN
In the Forced 'lane
THORNSPAWN's Avatar
It does sound ALOT like a big end bearing.
I spun a bearing in my supra and it sounded exactly the same
the knocking was actually the piston hitting the head hopefully you haven't done
too much damage but it's not as though they're expensive engines just build a better one
go on you know you want to ;)
XE S-Pack
4 Runner
XH11 Longreach
THORNSPAWN is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2005, 07:01 PM   #28
EASPRINT
FPV GT-P 335!
EASPRINT's Avatar
Ok guys....well just letting u know....my engine is coming out. So Will be out of action for a while... We're thinking its spun a bearing or bent a rod?. So i'll take it out...fix it, and drop it back in with an auto bolted on the back....
Old 25-08-2005, 07:04 PM   #29
LUXO_8
windsor user
bugger...
Old 25-08-2005, 11:22 PM   #30
EFFalcon
Last warning
EFFalcon's Avatar
easier to take it out anyway
