Old 25-08-2005, 06:21 PM   #1
Falcon_Awesome
Unhappy Blown Headgasket symptoms?
Hi, I think my car may have a blown head gasket. Just wondering what the signs of a blown head gasket are and how much would it cost to get it fixed?
Oh and sorry if this has already been asked, if it has can you please point me in the right direction?
Old 25-08-2005, 06:45 PM   #2
Age182
GMHKLA number plates
Age182's Avatar
it would run and idle ruff low water level and coolant marks down the left and rights sides of the block.
cost dunno im an apprentice mech i done it myself.
all so take out ya spark plugs and wind the motor over see if water shoots out
Currently owned: 1997 Hyundai Excel (the daily)
2009 FG FPV F6 Silhouette Auto
Previously owned:
1994 EF fairmont Ghia 4.0Ltr, AUTO
14.620@93.3mph
2000 Honda S2000
14.73@92mph (stock + no traction)
Age182 is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2005, 06:48 PM   #3
Brent-EA Ghia
Brent-EA Ghia's Avatar
Symptoms:
loss of coolant,
milky oil,
rough idle-missing on accell,
steam out exhaust,
rusty spark plug (electrode end)
or if its only external it could have stains down the block from the head gasket/
Proud Owner of 06' TTG
Brent-EA Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2005, 06:56 PM   #4
Falcon_Awesome
If I take off the rocker cover will that tell me anymore about it or is it a waste of time?
Ill check all this tomorrow, thanks guys
Old 25-08-2005, 07:12 PM   #5
Age182
Age182's Avatar
yea there the rocker cover will be white on the inside (milky oil) but its not always the case try the other things first
Previously owned:
14.620@93.3mph
2000 Honda S2000
Old 25-08-2005, 09:17 PM   #6
saudia_man
it depends which part of the gasket breaks. If it's a breakage and causes water to shoot inside the engine, then you will have rough idle, and rusty spark plugs, etc, but if it's a external leak, you will get water down the side of the block, and smell coolant in the engine bay when you open the bonet.
If the water passage leaks into the oil passage, then you will get milky oil.
Either way, you're gunna lose coolant, so keep and eye on the level. ive been losing coolant for a while now, but i cant figure out where its going or leaking from.
saudia_man is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2005, 10:54 PM   #7
Walkinshaw
Two > One
Walkinshaw's Avatar
Marks like that on the block would indicate a blown gasket or snapped head bolt.
Old 26-08-2005, 08:14 PM   #8
5speedeb
now with 3.73 lsd
on price depends where u go could be from $500 to $1500 if it needs to be done use a n au gasket
5speedeb is offline   Reply With Quote Multi-Quote with this Post
Old 26-08-2005, 08:29 PM   #9
BuuBox
Or follow the totorial on the website, spend maybe $200 at the most (worst case senario... $35 sounds better), and have something to do for the weekend.
It's not hard, just a little time consuming If you have some mechanical ability, you should be able to get it sorted.
BuuBox is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2005, 10:53 AM   #10
gozza
gozza's Avatar
when mine died i took it too ford
labour and recon of head/fitting gasket cost me around 1100
gozza is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2005, 12:23 PM   #11
Falcon_Awesome
I think I may have escaped a blown head gasket. The sparkies were jet black, there was a bit of oil on the thread and a very tiny amount on the electrode but that could have got there when I took it out. Would that make a car run really rough? And use a fair bit of petrol?
Old 27-08-2005, 05:10 PM   #12
Falcon_Awesome
Ok, so its not a blown gasket but theres a few other problems with it. I changed the sparkies today, running heaps better.
Its blowing alot of black smoke and sometimes (usually after coming down a hill and onto a flat surface) I go to put the throttle on and it does nothing, I have to pull over to the side of the road and put the throttle on about 1500rpm and wait for it to kick in.
Old 27-08-2005, 05:30 PM   #13
Hardtopxb
Once PHASED.
sounds like induction to me
Hardtopxb is offline   Reply With Quote Multi-Quote with this Post
