As I got home today, I noticed that my car was driving strangly so I decided to take a look at the tyres and on the right rear I noticed something strange. I took some quick spans with the phone.
What do you guys reckon it is and whats happening to the tyre.
COLORADO RED FIESTA ZETEC MODS - Window Tint, Bmc Panel Filter, Euro Plates, Ghia grill, Momo F16 leather gearknob, Momo Leather gearboot, WQ Zetec Front sway bar, WQ Zetec Sway bar links, WQ Zetec bushes. ICE - Alpine CDA9827, MbQuart Reference 6.5inch splits, MbQuart Reference rears, Rockford Fosgate Punch Stage 3 12inch Sub, Rockford Fosgate P4004 + P3001. |
striped
have you exceeded the speed rating of the tyre?? ;)
#3 | ||||
AFF's 1st DM.......
Flamesuit on...
FORD GIVING POWER TO THE PEOPLE Alloy headed 347ci EDXR8 13.21 @107.7mph Quote:
#4 | |||
striped
#5 | ||||
AFF's 1st DM.......
My EB2XR8
Sidewall damage. Looks like it has a small cut in front of it. You've hit something that's staked it, or someone has had a go at it. It could have been a manufacturing fault, but it looks like that cut may have something to do with it. Basically it's weakened it and the air is buldging out causing the bump. It'll be handling poorly because it's unbalanced I would suggest. Replace it. It might do nothing, or it might split, heat up and blow out causing you to end up somewhere you don't want to be. Officially I would call it unroadworthy as it is.
Guestimates from looking at the photos anyway. I could be wrong, but. Hope it helps. |
Petro-sexual
I'd say your issue with handling is that someone has driven quite hard into a gutter, or pothole and put your alignment well out of whack. The damage to the sidewall is the other result of the hit, but not the cause of the bad handling.
Clio 182 CUP!
I think Cypher had the same problem.... or similar with the side wall.....
------------- Steven 'In fact, so good is the Clio 182 with the Cup chassis set-up that I feel moved to make a bold statement - I think it's the best hot hatch ever built.' (EVO Jan 04) |
striped
glad to be getting rid of mine asap
I am the only one that drives the car and I can safetly say there as been NO hit's into gutters or potholes. The only thing I can think of if I glanced a round about but it was very softly.
#11 | |||
Clio 182 CUP!
------------- Steven 'In fact, so good is the Clio 182 with the Cup chassis set-up that I feel moved to make a bold statement - I think it's the best hot hatch ever built.' (EVO Jan 04) Last edited by Teki04; 05-09-2005 at 08:46 PM. |
#12 | ||
This happened more than a week ago (about a week and half). I doubt it was the cause as it only came up today and the impact was very soft. The tyre itself has been dodgy for some time with is loosing pressure slowly.
I need the car to get to school. Do you guys think it would be safe to drive it the 20minutes trip there and back? I could ask my friend for a lift if it is dangerous.
GRRRR.....
Definitly looks like impact damage to me, maybe that roundabout was harder than you thought?
#14 | ||
Rollin
tyre might of had a weak defect from new and hit to many pot holes etc grazed a round about or hit a speed bump quick and the tyre is buldging /egging, def needs to be replaced
#15 | |||
AFF's 1st DM.......
Hard to say it might last months or just hrs.
Dont you have a spare ?
#16 | ||
Clio 182 CUP!
Use the spare..... or take the bus?
#17 | ||
The fiesta use temporary space savers. It's not really an option.
#18 | |||
Clio 182 CUP!
#19 | ||
Fairmont Ghia
That happened to me in my Focus on my 15s - as they say, it could last either an hour or a month.
Even something really insignificant can do it, sucks, but what can you do... Get it replaced as soon as you can, it should be ok for a day trip, but there's always the risk it will blow out. Tim |
#20 | |||
GT4.
#21 | ||
Ute Forum Moderator
![]() Join Date: Dec 2004
How many km has the tyre/car done? You might try going to a tyre dealer of whichever brand tyres they are, and see what they can do about it. I wouldn't be driving that on the freeway as it is, but take it easy if you do drive it.
#22 | ||
Fiesta Zetec
My tyre side wall failed as well as some of you know. Pie, you might be lucky and get it replaced as it has not failed yet.
Bridgestone are very reluctant to do anything for you. With mine, they put it down to the valve failing (which may or may not have been the case as when the tyre went down, the bottom side of the valve is exposed and gets damaged). So thats the only thing they can point it to. I thought valves were warrantable, but apparently they are not according to bridgestone. Also, when Ford customer service rang Bridgestone on my behalf, the got abused for questioning their tyre expertise. Bridgestone just dont care. There was some admission that these tyres have had sidewall problems, the ER30. Suprisingly enough, none of these tyres were available in the country during August. In the end, I said F it as I am going to sell it so I couldnt be bothered. I wont be buying any more Bridgestone tyres any time soon. No doubt you can tell I am a little bitter about this. Interesting that you mention that the tyre was leaking pressure. I dont know what the cause of this is. Incidently, you may be lucky and get a result. At least the tyre did not fail on you which is a bonus of sorts. Pie, maybe give ford customer services (Ford CRC) a call on 133 673. If it helps you, I can give you my case number, pm me if you want it. If you go to Bridgestone I can also pm you my case number for reference and a contact at Bridgestone as he dealt with my case. Just ask me on msn. Incidently my tyre was also located on the righ hand side. Edit: The cracking that your tyre seems to be experiencing is consistent with what the cracks look like on mine. Mine had 19,800km on it when it failed. The tyre orignal was equipped to the front right and moved to the rear right at 15,000km. I dont think many more of us have this many km so maybe a problem has not surfaced yet.
:lookedat: Last edited by Cypher; 06-09-2005 at 02:28 PM. |
#23 | ||
Candy White GTI
The space saver is extremely dangerous. i drove with it on for around 4 km doing about 40kmph and ive never felt such an unstable and unsettled car in my life.
Volkswagen GTI Polo. Candy White, Anthracite heated Sports leather seats w/ Red stitching.Tinted Windows, Eibach Pro-Kit springs,Whiteline Front/Rear adjustable sway bars,Cupra R intake, Forge Turbo Inlet pipe,BMC panel filter, APR stage one flash, Dunlop SP sport MAXX, Forge Polished upper front strut brace. 3'' downpipe and highflow cat Loads of fun ![]() |
#24 | ||
striped
the space saver is designed to get you short distances to get the original fixed.
if it was "dangerous" then it wouldnt have been allowed to be fitted to the car. |
#25 | ||
Fairmont Ghia
I think the space savers are speed restricted anyway, the manufacturers certainly don't approve of their use at normal operating speeds and conditions. It's to stop you walking the 300kms to the nearest tyre shop and carrying a new one back, because you didn't want to lose an extra 3cm of bootspace.
Tim |
#26 | ||
Clio 182 CUP!
In regards to the spare.... i used it to get to my local tyre shop, and i dont see any harm in using one. You just have to be aware the car might feel different, but mind you it wasnt unstable. Only thing that was a pain in the **** is putting the Spare back on.... you will NEVER be able to screw it! lol. I got a new screw ordered today under warranty, as mine was bent?!
#27 | ||
Fiesta Zetec
Spave savers are rated at max speed 80km/h. I drove on mine for about 40km. No problem but in the rain, its a little sketchy!
:lookedat: |
#28 | |||
AFF's 1st DM.......
Too bad if your like 400k's from nowhere @ 80km/hr
#29 | ||
striped
steal someones wheel and use it to replace your space saver
#30 | ||
GRRRR.....
technically space savers are illegal, i.e. different sized wheel and tyre fitted to car....... but 'technically' spare tyres are'nt a roadworthy item. But if it gets you out of trouble, its done its job.
Oh, try not to wear them out either, VERY expensive to replace. |
