Old 07-09-2005, 12:34 PM   #1
Felony
Wherever u go there u r
Default Changing 3.9 to 4.0 in EA
I have a 89 ea fairmont and im about to convert to manual, then a month or so after that i will have finished my 4litre for it, does the 4 litre engine accept the 3.9 manual flywheel and clutch?
thanks
Felony is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2005, 12:35 PM   #2
Kaddis
Kaddis Customs
Kaddis's Avatar
im pretty sure i read somewhere that they dont line up....i might be wrong tho
FG XR6 E-Gas Ute in Ego
Kaddis is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2005, 12:38 PM   #3
Perana
Perana's Avatar
3.9 Flywheel and clutch will fit on 4.0L crank.
I would go a 4.0L flywheel and clutch though since it is a fair bit stronger.
'09 SYII TTG | Mystic
'06 BF XR6 | Mercury Silver
Perana is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2005, 12:46 PM   #4
Felony
but the t5 box physically bolts to 3.9 and 4.0 blocks?
Old 07-09-2005, 12:54 PM   #5
Perana
Perana's Avatar
Yes it does... only complication is when AU Engines are involved.
Old 07-09-2005, 12:55 PM   #6
bakes_eb
bakes_eb's Avatar
I just put a t5 box into my 4L eb i used the 3.9 flywheel and clutch had to problems at all.
cheers scott
'93' EB fairmont
5 speed manual.
extractors, high flow cat, 2.5 inch sports exhaust.
Freshly painted in Cobalt Blue.
lowered with ultra lows.
17 inch mags fitted.
Just finished putting a low km el motor in her
bakes_eb is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2005, 12:57 PM   #7
Felony
thanks lads,
cheers
Old 07-09-2005, 09:48 PM   #8
DOMN8N
AKA ___DOMMUZ
DOMN8N's Avatar
i put a 4.0 in my ea but it had the fly wheel and reco gihabox but i think it should go on ok you can only try i had to change the intire loom and chip
DOMN8N is offline   Reply With Quote Multi-Quote with this Post
