Old 07-09-2005, 05:44 PM   #1
BoZZa17
Lovin the Manual.
BoZZa17's Avatar
Default Car takes a while to start and no top end pwr?
hey guys...
when my car has been sitting for an hour or so or more... it will crank for ages before it fires.. like an old ty car on gas (well i guess it is an old ty car.. BUT NO GAS)
anyway... when the car is warm it starts easier but still will crank more than it should before it fires..
once the car is running it is smooth however after 3000rpm or so the power seems to die off.. like if i dyno's it my peak ov the power curve would b at 3000rpm then just stay constant... the car will rev out to 5000 no probs but just doesnt have as much pull as it should
any ideas?
oh.. i have changed fuel pressure regulator.... and fuel pump to no avail...
thanks
BoZZa17 is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2005, 05:48 PM   #2
InitialD
Low and Loud
InitialD's Avatar
injectors? what are they like austin?
Old 07-09-2005, 06:09 PM   #3
CruizinEB
maby the starter motor?
CruizinEB is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2005, 06:13 PM   #4
svo347
AFF's 1st DM.......
svo347's Avatar
hmmmmmm maybe not that
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 07-09-2005, 06:13 PM   #5
svo347
AFF's 1st DM.......
svo347's Avatar
Got a spare tfi module handy
13.21 @107.7mph
Old 07-09-2005, 06:16 PM   #6
CruizinEB
but thats what happend with mine?
Old 07-09-2005, 06:37 PM   #7
neb
hibernating
neb's Avatar
checked the ignition timing?
neb is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2005, 06:41 PM   #8
LUXO_8
windsor user
plugs and leads....
mine was dying off after 3000 / 3500, and its been a while since i changed em, so i figured it couldnt hurt to do.
revs out smoothly now with no flatspotting... might be worth you checking
Old 07-09-2005, 06:42 PM   #9
svo347
AFF's 1st DM.......
svo347's Avatar
What it would crank & crank but not start??
13.21 @107.7mph
Old 07-09-2005, 06:43 PM   #10
LTDHO
The one and only
LTDHO's Avatar
That's the first thing I'd check.
Tuned by CVE Performance
Old 07-09-2005, 08:41 PM   #11
Jason[98.EL]
Jason[98.EL]'s Avatar
GDAY THERE
If you are confident pull the dizzy out and check for play in the shaft sounds alot like what happenned to my old man this week and yes he is an agrade mechanic with 40 yrs experience and he found that the shaft was worn (in a 89 ea fairmont ) and had rubbed against the wire inside the dizzy once replaced starts fine every time now
hope this helps
[SIGPIC][/SIGPIC]
Old 07-09-2005, 10:12 PM   #12
BoZZa17
Lovin the Manual.
BoZZa17's Avatar
hmm...
ta 4 replies
i got new plugs last week...
ill check timing ...
mmm dont hav a spare tfi to try
and the shaft play...mm.... well ill check timing 1st..
Old 07-09-2005, 10:14 PM   #13
BoZZa17
Lovin the Manual.
BoZZa17's Avatar
oh and injectors?
im not sure,, i guess theyre pretty old
is there an easy way to check their condition?
Old 08-09-2005, 07:33 AM   #14
LTDHO
The one and only
LTDHO's Avatar
Originally Posted by BoZZa17
oh and injectors?
They should be cleaned at least every 100,000.
I did my ex-GF's at 70,000 so it would keep effiecient.
If you have done over 150,000 and you doubt they have been done, take them out and get them reco'd.
