12-09-2005, 12:26 AM | #1 | ||
Hi guys,
just a quick question - where abouts is the EGO sensor mounted in an EA ( / maybe EB i think they are similar?) Im not familiar with the falcon exaust (ive never poked my head under one for a look), is it somthing like CAT - muffler - resonator - out? Where abouts in the line is the EGO sensor located? Also does anyone have a falcon wiring diagram? There are two white lines going into the sensor for the heater and one for the signal out. Is the heater just wired to 12V? |
12-09-2005, 12:30 AM | #2 | ||
Low and Loud
the HEGO sensor is screwed into the exhust manifold just above where the cat bolts onto the exhaust manifold
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon : |
12-09-2005, 12:34 AM | #3 | ||
Confused
the ego sensor is the in the exhaust manifold just above the flange. from memory the heater has 2 12 volt feeds and the signal wire. these should be red/green and black/green for the 12v, and green/blue for the signal on a standard harness.
hope this helps |
12-09-2005, 12:40 AM | #4 | ||
Ahh ok, so its right up the hot end?
I guess the heater is used when the engine is just starting up and cold? And the two white wires are both 12V - thanks! There definatly not voltage reduced through a resistor or somthing? So its grounded through the exaust? Wonder how gaskets and things effect using the exaust as a ground. Last edited by davo123; 12-09-2005 at 12:53 AM. |
12-09-2005, 08:07 AM | #5 | |||
Does Steve have a car?
AKA Mr Silver Chasing reliability....: "When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
