Old 23-09-2005, 05:11 PM   #1
XR6ST
XR6ST's Avatar
Default Electric Fuel Pump for 2.0 Pinto in RS2000???
Anyone got any recommendations as to what type of Electric fuel pump I should get to replace the stuffed mechanical pump in my '79 RS2000 Escort, and if a regulator is required, what pressure is ideal? The engine is currently being rebuilt, mostly stock but will be balanced, 60 thou over, have a mild cam for a while (until I replace the auto tranny with a manual), as well as a set of extractors and possibly twin dellorto's. Later down the track it should end up with a ported head and a wilder cam to maybe do some club racing (supersprints, hill climbs etc) but will still be registered and street driven.
XR6ST is offline   Reply With Quote Multi-Quote with this Post
Old 26-09-2005, 03:02 PM   #2
THORNSPAWN
In the Forced 'lane
THORNSPAWN's Avatar
I have a Carter electric fuel pump in my RS2000 with twin 45mm webbers.
The pump is around 14psi which is a bit high so I need a regulator aswell
it cost me $135 but I htink normally they're about $200 and they're definately needed
with bigger carbys as the standard mechanical pump couldn't keep up at higher revs
XE S-Pack
4 Runner
XH11 Longreach
THORNSPAWN is offline   Reply With Quote Multi-Quote with this Post
Old 26-09-2005, 07:43 PM   #3
XR6ST
XR6ST's Avatar
Thanks Thornspawn, much appreciated. What pressure range is the regulator you are running?
Old 26-09-2005, 08:00 PM   #4
THORNSPAWN
In the Forced 'lane
THORNSPAWN's Avatar
I don't have one yet the car is being painted at the moment and I'm doing the
engine bit by bit. I'm almost finished just need a regulator and half decent
ignition system.
XE S-Pack
4 Runner
XH11 Longreach
