Shockworks
Old 01-10-2005, 10:12 PM   #1
chief
FTF Club Moderator
chief's Avatar
Default Dealer servicing
Just has my car at Titan Ford for the 105,000 km service, and was wondering do any other members let dealers service their car or someone else. Sure for warrenty purposes but what about general matainance? Have you had good or bad service at dealers?
I got my car back and the LHS brake light, RHS tail light and a LHS parker light was not fixed. But they did wash the car and I would of prefered to do it myself. It was already clean before it went to them and they washed it and came back dirty. All well, long weekend to clean the car.
Dealers do charge an arm and a leg and what is the go with an "approved technian" always wanting to change your wiper blades? :
Albert Einstein:
Fords in the Park 2010
Old 01-10-2005, 10:32 PM   #2
b2tf
not here much anymore
b2tf's Avatar
Ohhhhh don't get me started....... :ticking: :
2024 F150 XLT
Old 01-10-2005, 10:40 PM   #3
howey
I would like to think that there are good and bad deales, just like there are good and bad non dealers. I do have a fairly large conflict of interest though.
howey is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2005, 10:55 PM   #4
Sunburst50
Sunburst50's Avatar
I used my local Ford dealer while the car was under warranty but when it ran out I started taking it to my local Ultra Tune because the dealer wanted to charge too much for work that did not need doing. At the 60,000km service they wanted about $400 for new front pads and disc machining. That work was just done at 92,000km for $185 .
I have been using Ultra Tune for about 9 years now for all the cars I have owned in that time and have had no problems at all. The only thing I find is that they are getting more expensive but not as bad as the Ford Dealer.
Sunburst50 is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2005, 07:43 AM   #5
Yaw
Ford Fanatic
Yaw's Avatar
I bought my Escape in February used from Byrne Ford, it came with a 175,000 / 3 year extended warranty. To keep this warranty I must have a basic service every 6 months or 10,000 klm. Its a fixed price basic service of $175.00 that is just the service though. So to keep my warranty up I will do this and any other problems that arise get somewhere like ultratune to do.
I will say though when I bought the escape it had a common problem that a lot of Escapes have, an auto trans shudder. I did my research and found that ford had a tech service bulletin about it and the dealer did not charge me for that work and was done with a smile. So, its so far so good with Byrne ford in my experience, I am wary though after so many threads about dealer servicing on AFF. As i have a good grounding in mechanics its hard for them to pull the wool over my eyes.
Everyone is entitled to my Opinion
2007 Territory TX SY RWD Ego
Yaw is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2005, 08:27 AM   #6
deesun
deesun's Avatar
Well CHIEF
"Would you believe all dealers do a good job and at reasonable cost?'
No Max
"Would you believe some dealers?"
No Max
"How about 1in 100?"
Getting close Max. :hihi:
igodabigblackshinycar and I relented and allowed a BMW into the garage.
deesun is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2005, 08:31 AM   #7
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Some might say
Missed it by that much...
Old 02-10-2005, 08:48 AM   #8
chippa6
Novice Professional
chippa6's Avatar
I got ford to service my car just before the warranty ran out and they quoted over $300 to flush the gearbox. I got a quote for $185 from ultra tune, or $110 for a single flush/$145 for dual flush from a good gearbox guy down the road. I got it done for $145 it it is great.
I overheard the "road tester" technician telling a customer that when cars are brought in for servicing at ford that they update/flash the ecu with the latest version. anyone heard of this at all?
2001 AU XR6 - Narooma, Aunger CAI, K&N, Kings S/Low, Extractors & Exhaust.
chippa6 is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2005, 10:15 AM   #9
b2tf
b2tf's Avatar
Not always. They will only do it if required, not as a regular thing.
2024 F150 XLT
Old 02-10-2005, 11:23 AM   #10
Dezza
Parts bin special
Dezza's Avatar
I don't. My parents do. One time, when they had the car serviced, the engine also got a degrease. Driving home, the car stalled and wouldn't restart. Water in the distributor. They fixed the problem, but it still shouldn't have happened.
On the other hand, when I had a wheel alignment, not at a Ford dealer but at a seperate mechanic, I was driving home and lost my front right wheel! Mechanic hadn't done the wheel nuts up properly. Sorted it all out for me as well.
Shows all mechanics can make mistakes, not just Ford dealers
Old 02-10-2005, 12:25 PM   #11
LTDHO
The one and only
LTDHO's Avatar
Once you are out of warrenty, don't go back to Ford and when buying the car don't be suckered into paying extra for extended warrenty, you are just puting more money into their pockets and getting nothing in return.
Tuned by CVE Performance
Old 02-10-2005, 01:45 PM   #12
aimzes
...fairly odd
aimzes's Avatar
for routine servicing would you be best to go to a place like ultratune just so your warrenty isnt void and you get your logbook stamped then only take it to ford if something needs fixing under warrenty? i.e your gearbox breaks.
1992 EB Falcon 5.0 V8. mods; dust, dirt, cobwebs, scratches, trolley dents, dented bonnet, gutter scrapes, rattly exhaust, and floor mats.
aimzes is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2005, 02:16 PM   #13
jonbays
TL40 Wagon?
most dealers run the service side because they have to to keep the franchise and really only can afford to carry all the tools staff and parts by charging very handsomely.
Stay away if you can find a good workshop who you can trust.
Old 02-10-2005, 02:21 PM   #14
Melz
Melz's Avatar
I've taken one car to a dealer (won't be going back) and another to an independant mechanic. The other two i see to myself or my old man sees to them.
The primary reason I won't go back to a dealer is my local couldn't pick the stuffed timing belt and thought it was a spark plug problem...Even i knew the difference, then when i said no just fix the timing belt.. they wanted $600!!!!!! Needless to say car got trailered to somewhere else and fixed.
Originally Posted by Jeremy Clarkson
“The Americans lecture the world on democracy and then won’t let me turn the traction control off!”
Melz is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2005, 03:03 PM   #15
buickman
buickman
buickman's Avatar
I'am with you on that.
My last warranty claim that got fixed I had to ring Ford customer service to get the dealership to replace the Climate control unit.
Within just over 12months out of warranty the ball joint end snapped of that holds the strut for the boot on the right side & no way would Ford come to the party saying it was not a rust issue & out of warranty. So the only time its seen a Ford dealership since is the recall to fix the rack bolts on the AU
buickman
