Old 03-10-2005, 10:26 AM   #1
bakes_eb
bakes_eb's Avatar
Default 3.9L and 4L waterpumps
Hey guys are they the same will the 3.9L fit straight onto the 4L?
cheers scott
'93' EB fairmont
5 speed manual.
extractors, high flow cat, 2.5 inch sports exhaust.
Freshly painted in Cobalt Blue.
lowered with ultra lows.
17 inch mags fitted.
Just finished putting a low km el motor in her
bakes_eb is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2005, 10:28 AM   #2
EA2BA
PM me if you want
EA2BA's Avatar
YES
I have a 4L EL water pump in my EA 3.9L at the moment.
Of course the pulley has to match your belt/belts
Old 03-10-2005, 10:31 AM   #3
bakes_eb
bakes_eb's Avatar
cheers dellboy.
'93' EB fairmont
5 speed manual.
Old 03-10-2005, 04:51 PM   #4
Rmyers
Does Steve have a car?
Rmyers's Avatar
Any water pump will bolt on from EA-BA. EF-BA pumps wont work with the EA-ED triple belt drive tho if that's what you were asking...
AKA Mr Silver
Chasing reliability....:
"When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
Rmyers is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2005, 07:46 PM   #5
NZ
NZ's Avatar
the ef - ba pump also spin in the other firection and have the wrong outlet size.
Old 04-10-2005, 08:05 AM   #6
Papa Smurf
Papa Smurf's Avatar
EA-ED Water Pumps are the same and EF-BA (to 11/2003) are the same then the BA one changes.
Papa Smurf is offline   Reply With Quote Multi-Quote with this Post
Old 04-10-2005, 11:57 AM   #7
bakes_eb
bakes_eb's Avatar
thanx guys for the info.
'93' EB fairmont
5 speed manual.
Old 04-10-2005, 07:43 PM   #8
eafalcon
I think u will find that the EF/EL pumps are different. U cant change the pully without a special puller and the outlet to the bottom hose is smaller than an EA/EB/ED. I know from experience. Also EF/EL bottom radiator is different to match
eafalcon is offline   Reply With Quote Multi-Quote with this Post
Old 04-10-2005, 08:57 PM   #9
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
I disagree - it is possible! Resulted in total destruction of the first pump though... definitely not recommended.
Old 04-10-2005, 10:59 PM   #10
spope
spope's Avatar
EF/EL/AU Pumps are identical, run the same pulley as well.
EA series 1 run a v-belt
EA series 2 - ED run a 3 rib belt
Pulleys are not interchangable between EA-ED and EF/EL/AU on account of the early pumps the pulley is bolted on and there is a thread for the clutch fan. EF/EL/AU have a pressed pulley
The water outlet on the EF/EL/AU is narrower than EA-ED.
However, they all bolt up exactly the same - so just use which is applicable to your particular belt setup.
spope is offline   Reply With Quote Multi-Quote with this Post
