03-10-2005, 11:22 AM | #1 | ||
How do you put an EB2 into self test mode? I'd like to set my base idle and timing again with the new engine management.
I know with an EA it's easy, just ground the self test connector - but the EB2 doesn't have one of them, just the multi-pin output under the fuse box. Also, is it still possible to read codes out of an EB2 ecu like you can with an EA one using a test light? Any info appreciated. |
03-10-2005, 01:27 PM | #2 | ||
In the connector the far left top and bottom. Bridge them then start car.
Yes it is possible to read codes but i have NFI how to |
