Old 31-01-2005, 03:14 PM   #1
free-energy64
Free Energy Is Out There
free-energy64's Avatar
Question Which Head Gasket Set????
Greetings all, have a couple of queries, has anyone dealt with Gimmecarparts.com.au? Are they OK to deal with? and I've found 3 ACL Monotorque head gasket sets which all seem to fit my car, but which on is the correct set to use? From compliance plate in engine bay Model 18364, Engine H and Built June 1994. Parts from gimmecarparts.com.au as follows:
Part No. HS520MT Ford 4.0l EB-ED Inline 6 SOHC 2v $67.52
" " . HS522MT " " " " " $68.74
" " . HS522MTG " " " " " $71.41
If anyone can help I would sure appreciate it. I've been told that the ACL Monotorque are the gaskets to use, does everyone agree??
Thanks Paul.
free-energy64 is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2005, 07:18 PM   #2
Walkinshaw
Two > One
Walkinshaw's Avatar
The Monotorque gaskets are good, but why not use the AU steel gasket for a few extra points of compression whilst the heads off.
Old 31-01-2005, 09:14 PM   #3
free-energy64
Default AU Steel Gasket?
Hi, if this a better option OK. Does anyone know the part number? Or can any AU steel gasket be used? Thanks.
Old 31-01-2005, 09:15 PM   #4
EFFalcon
Last warning
EFFalcon's Avatar
just goto ford and ask for an AU II Headgasket.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 31-01-2005, 09:56 PM   #5
TIKFD6
Number 5 is alive!
TIKFD6's Avatar
Use an AU gasket.
Worth the few extra $$$$.
Kerry
Tickford wings are for Tickford cars!
"Experimental Racer" #6
1994 Gunmetal XG XR6 1997-1999
[B][COLOR=Red] 1994 Le Mans Red ED
2008 MA XR5 Mondeo
2015 VOLVO V60 T6 R-DESIGN-POLESTAR Enhanced
TIKFD6 is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2005, 10:12 PM   #6
InitialD
Low and Loud
InitialD's Avatar
Monotorque Gaskets are what ive been recommended to by many Engine reconditioners. Those Cheapo Supercheap Auto ones are terrible.
Old 31-01-2005, 10:16 PM   #7
trick_xd
I build your wish list...
trick_xd's Avatar
$68 for the AU II head gasket from ford
$25.70 for head bolts from bursons
its the best $100 you will spend on your motor
If it weren’t for physics and the law enforcement, I’d be unstoppable.
trick_xd is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2005, 06:03 AM   #8
free-energy64
Thanks heaps for the feedback, seems like I had better go with the AU steel gasket.
Old 01-02-2005, 06:29 AM   #9
free-energy64
By the way, will I have to replace all the other gaskets aswell? Buy a gasket set? What gasket goo is the best.Q's, Q's and more Q's. Thank God for you people on this forum!!!!
Old 01-02-2005, 08:30 AM   #10
EFFalcon
Last warning
EFFalcon's Avatar
damn.... i paid like $70 for headbolts from ford :o
i know not to do that again...
depends on the condition of the gasket, intake manifold gasket is usually ok, exhaust gasket depends (i had to replace mine), i'd replace thermostat housing gasket anyway.
rocker cover depends if its leaking or not.
i've got selly's blue gasket stuff... and the bronze stuff for the exhaust side
Old 01-02-2005, 09:20 AM   #11
Sox
RIP...
Sox's Avatar
Agreed, the metal AU gasket is the best option.
Rick.
Oval Everywhere...
Old 01-02-2005, 11:07 AM   #12
spope
spope's Avatar
On that note, though, the torque sequence is different if you are using an AU head gasket + bolts, isn't it?
I know EA-ED is 40 Nm + 90 degrees... what is AU?
spope is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2005, 11:12 AM   #13
EFFalcon
Last warning
EFFalcon's Avatar
30nm + 120 degrees
Old 03-02-2005, 10:54 AM   #14
Thanatos
E-Series Owners Club
Thanatos's Avatar
The AU Gasket is the best option IMO.
But as for those three part numbers - ACL make three different thickness gaskets: Standard, thinner (to raise compression), and thicker (to lower compression). Not sure which part number realates to which gasket though...
Thanatos is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2005, 06:56 PM   #15
SileNceR
02/90 EA II Fairmont
SileNceR's Avatar
autobarn should be able to look up the part numbers... go find them out there and if you can get them cheaper elsewhere, do so
211RWKW EA
SileNceR is offline   Reply With Quote Multi-Quote with this Post
