Old 16-10-2005, 06:25 PM   #1
BlOWN-EA
BlOWN-EA's Avatar
Default ea diff gears
few questions
the ea diff obviously has a different tail shaft mounting bit its got the u-bolts. where as later models have the flat mounting circle thing, if i want to use diff gears from say eb to au etc am i able to?? with out changing tail shaft etc?? and can i use the u-bolt design on the end of the other pinion gear shafts etc? is anyone selling gear sets about 3.27 or above??? thanks guys
No. Of Snapped Axles So Far: 2
BlOWN-EA is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2005, 06:34 PM   #2
svo347
AFF's 1st DM.......
svo347's Avatar
as far as im aware you can unbolt the flange & swap it right over.
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 16-10-2005, 07:04 PM   #3
Key
why not just use the whole diff assemby and the tailshaft from a later model?
Key is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2005, 02:34 PM   #4
24CIT
back to the shop........
24CIT's Avatar
What centre/ratio are you thinking of using? i'm using 3.25 with a romac drag minispool!
Bow to the turbo
24CIT is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2005, 05:27 PM   #5
BlOWN-EA
BlOWN-EA's Avatar
anything i can get my hands on
