Old 17-10-2005, 06:42 PM   #1
yo_stock
Default Trip computer into EAII
Hi all, i have just installed a trip computer from EA fairmont into my EA gl, I have left one wire out, (ran out of daylight...) This wire is the one that goes to the injectors, the "Fuel Injection PWM Output on EECIV" green/yellow
What the question is, when i put ignition on the "range" starts beeping at me saying i have zero litres left, or kms.
I have retraced and double checked the fuel sender that goes to my dash, and thats working good, would it have anything to do with this PWN wire not connected? cheers.
yo_stock is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2005, 06:46 PM   #2
CruizinEB
i,m not shore but i think all wires need to be wired up for it to all work correctly
CruizinEB is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2005, 10:59 PM   #3
EA_Bender
Hmmm Gold!!!
EA_Bender's Avatar
well another well thought up post there....
simmo and me just wired up his tonight as well, it was beeping and range read zero as well, then we plugged the cluster back in and it came good, so if you've got the cluster out wack it back in and see how it goes.
I've currently get half my dash out and will be finnishing it tomorrow as well as i ran out of light as well...
bender
1990 EA Series 2 Fairmont, Low Springs and shocks, 17 x 7 Advanti Flash Mags running on Falken rubber :, EL XR8 Sway Bars, NGK Iridium Plugs, New Trip Comp, Pacemaker 4480, 2.5 system 4L ED engine with surecam
Now Sporting - OED666's 202+ RWHP engine!! :dj: fully
EA_Bender is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2005, 11:08 PM   #4
spope
spope's Avatar
The pulse width wire needs to be hooked up for the "Range" and "L/100 km" functions to work - it needs to know the injector pulse to work out how much fuel is being used.
Also, the cluster has to be plugged in to earth the fuel sender circuit. Don't ask me why, it just does. ;)
The pwm wire is pretty easy to get to though - just unravel a bit of the tape at the ecu connector, you should find the green/yellow (iirc) wire easy enough. I just used a scotch lock when I did mine.
spope is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2005, 06:38 AM   #5
yo_stock
I had the cluster in and it was stil beeping, i'l do the PWM wire this arvo, see how i go, would it take a lil time for computer to reliased it was earthed? cause i didnt have the cluster hooked up for long.. cheers
Old 18-10-2005, 06:39 PM   #6
yo_stock
Well, i just hooked the PWM wire up, no change to range at all, it also is blowing water out the exhurst now.. all i wanted was a clock. mite jus go buy one of them.. anyone else with an idea? cheers.
Old 18-10-2005, 07:08 PM   #7
mcflux
mcflux's Avatar
If you're just after a digital clock, I'm pretty sure that the EA-ED clocks are an easy retrofit (maybe even plug straight in, if you have a loom already behind the blank where a clock/trip computer is normally housed). There are plenty on Ebay! You should get one for $30 or less (most likely around $20).
-Dave-
Old 18-10-2005, 07:43 PM   #8
Brent79
Be careful as there are actually 2 green/yellow wires that are in the ECU connector...
Brent
Brent79 is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2005, 08:46 PM   #9
yo_stock
Yes i noticed this, and i pluged it into the one on the middle run four up form main bolt, this is what the tutorial sais, so it should be right... Thanks all
I do want a clock, but when i got this, thought it would be good also
Old 18-10-2005, 09:32 PM   #10
BlOWN-EA
BlOWN-EA's Avatar
whats involved in doing it, how much dash do ya gotta pull out? and do the wires from the trip computer have the other wires sitting there waiting or do you have to probe into a heap of random wires?
No. Of Snapped Axles So Far: 2
BlOWN-EA is offline   Reply With Quote Multi-Quote with this Post
Old 19-10-2005, 06:06 AM   #11
yo_stock
This is a tutorial some one made up, will help you
http://www.fordmods.com/phpBB2/documents.php?doc=46
Old 19-10-2005, 05:57 PM   #12
yo_stock
Well, thank you every one who helped, took car for a run, after about 5 mins it started working.. wow, i happy now, knew all my wiring was correct..
Thanx alot.
Old 20-10-2005, 08:54 PM   #13
SileNceR
02/90 EA II Fairmont
SileNceR's Avatar
yeah was about to say, mine took a day or two before the range started working the first time... nfi why...
211RWKW EA
SileNceR is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2005, 09:20 PM   #14
yo_stock
Mad, does yours dimm with the lights or stay bright?
Mine isnt dimming, but it chimes when lights left on...
Old 20-10-2005, 09:33 PM   #15
EA_Bender
Hmmm Gold!!!
EA_Bender's Avatar
hey i just installed mine a couple of days ago too, mine doesnt dim and it does chime when the lights are left on (i love that feature)
Old 20-10-2005, 10:32 PM   #16
InitialD
Low and Loud
InitialD's Avatar
The Trip computer wont Dimm with your other dash lights unless your using Ghia dash wiring. Its controlled by the Ghia BEM
Old 20-10-2005, 11:21 PM   #17
EA_Bender
Hmmm Gold!!!
EA_Bender's Avatar
ahh well ive just got the faimont, not the ghia option so that explains it
Old 20-10-2005, 11:23 PM   #18
InitialD
Low and Loud
InitialD's Avatar
that can be fixed with a ghia loom or two :P
Old 21-10-2005, 06:36 AM   #19
yo_stock
Thanx for that InitialD, thought that would be the case. I'm happy now its al working :voldar02:
Old 21-10-2005, 06:42 AM   #20
yo_stock
Sorry i posted twice amd cant delete this one... Ooops
