01-02-2005, 05:08 PM | #1 | ||
Interceptin'
Hey guys,
For some reason my King Spring Low's look to me like the back end is lower than the front end. And the back end does seem to bounce a bit more than the front telling me the front is stiffened more than the back, maybe. I'm not too sure. So first - Is this normal ? and Second - If not should I stiffen the rear or un-stiffen the front ? Thanks
'95 EF II Falcon, 'INTERCEPTOR' '72 XA Fairmont Coupe, 'XA Muscle' |
01-02-2005, 05:24 PM | #2 | ||
Interceptin'
Maybe it's just the rear wheel arch...
01-02-2005, 06:12 PM | #3 | ||
The EF/EL can look lower at the back due to the wheel arch being lower. Measure the height of the sills at each end (where you would use your scissor jack) and see if it is actually lower.
Current Rides: 2012 KK Jeep Cherokee Limited CRD - Still going strong 2019 MG ZS Essence 1988 RD Mitsubishi Colt GL - 59kW of Fury 2022 Kia Stinger GT |
01-02-2005, 06:18 PM | #4 | ||
Interceptin'
Rear = 150mm
Front = 170mm It's noticeable because the rear arch meets the tyre and the fron arch has about an inch clearance :( (And no, no dead body's in the boot, ey madnc :P)
'95 EF II Falcon, 'INTERCEPTOR' '72 XA Fairmont Coupe, 'XA Muscle' Last edited by Interceptor'85; 01-02-2005 at 06:30 PM. |
01-02-2005, 06:34 PM | #5 | ||
windsor user
my car is the same, with pedders low springs
are you running standard shocks? thats what ive put mine to lmao at the body comment. i wasnt going to say anythnig tis time! Last edited by LUXO_8; 01-02-2005 at 06:37 PM. |
01-02-2005, 06:42 PM | #6 | ||
Yeah thats like mine too.
Wouldnt want the front any lower without rolling the guards though...
Me fail English? That's unpossible.
01-02-2005, 06:57 PM | #7 | ||
Interceptin'
Noop, don't have standard shocks, I've got Monroe GT shocks.
01-02-2005, 07:00 PM | #8 | ||
windsor user
what i meant was do you have standard height or short travel shocks
i have monroe GT standard height shocks in mine. |
01-02-2005, 07:05 PM | #9 | |||
Interceptin'
BTW Do you think the front is stiffened? They do seem compressed a bit.
'95 EF II Falcon, 'INTERCEPTOR' '72 XA Fairmont Coupe, 'XA Muscle' Last edited by Interceptor'85; 01-02-2005 at 07:08 PM. |
01-02-2005, 07:22 PM | #10 | ||
Bugger, that is quite a difference. They didn't give you V8 springs for the front did they?
01-02-2005, 07:37 PM | #11 | ||
Custom user title
looks better with the back lower than the front..... nothings worse than the back higher than the front
01-02-2005, 07:38 PM | #12 | ||
it's the front struts. Put a set of Pedders SportsRyder struts in the front and it'll sit about an inch lower. Plus you keep the same suspension travel. Might have to roll the guards depending on what wheels you have though. The reason for it sitting lower is cause the Pedders struts have a lower spring land on them than the Monroes.
01-02-2005, 07:41 PM | #13 | ||
windsor user
as do koni's.
should have my superlow / koni shock combo in by all ford day..... hopefully |
01-02-2005, 08:00 PM | #14 | ||
Struts wont affect ride height at all unless they have a lower spring seat, like Sphell has said with some of the pedders gear, I'd be checking ya rear control arm bushes first, my car went up 10-15mm in the bum after replacing brocken bushes
Ed |
01-02-2005, 08:36 PM | #15 | ||
Custom user title
if u get under and crack all the bolts then tighen them up again it will lower slighlty.. this wont work if u have nolathaine bushings
02-02-2005, 10:24 AM | #16 | ||
Interceptin'
That's interesting about the bushings, I'll give the underside a good look over.
Thanks guys!
02-02-2005, 10:57 AM | #17 | |||
My ED ended up with a droopy **** end with King Low's as well. First thing I also noticed when driving was the higher rate front, lower rate rear springs. It seems to give a decent ride/handling trade off. Car shown below even with 1' taller rear rubber.
Nothing looks worse than a lower rear-end IMHO. But maybe I'm just showing my age, I love the nose-down stance that rodders and old school muscle cars have. Rubber-rake rules!
. Last edited by Raptor; 02-02-2005 at 11:00 AM. |
02-02-2005, 02:59 PM | #18 | |||
Interceptin'
02-02-2005, 05:41 PM | #19 | ||
BF F6, APV SR3900
hmm i reckon my car has dropped in the *** lately.. where are the bushes, where do i look,
thanks
Santo White APV SR3900 [WIZZRD] (Click Here) [/COLOR] Daily: 2006 Red BF F6 Typhoon Bluepower enhanced. |
02-02-2005, 05:53 PM | #20 | ||
windsor user
i agree as well that having the front higher looks ghey looks like you have a few dead bodies in teh boot ey EF machine.(whats ya name btw, EF Machine is so annoyin to type out)
02-02-2005, 06:26 PM | #21 | |||
On another thought, are the springs properly seated?
02-02-2005, 07:07 PM | #22 | |||
That's all very well and good but E-series aren't rods or old skool muscle cars lol ;) I agree with injected 250 :hihi: |
02-02-2005, 07:32 PM | #23 | |||
02-02-2005, 07:57 PM | #24 | |||
5 Speed EL Futura 140rwkw last dyno |
02-02-2005, 08:12 PM | #25 | ||
windsor user
i like when the rear is about 15mm - 20mm higher than the front, on a lowered car.
how my car is at the moment, the rear looks like its lowered and the front looks like standard. must change asap |
02-02-2005, 08:15 PM | #26 | |||
Interceptin'
02-02-2005, 08:16 PM | #27 | |||
Interceptin'
Yeah my front end looks standard height too, compared to the rear.
'95 EF II Falcon, 'INTERCEPTOR' '72 XA Fairmont Coupe, 'XA Muscle' Last edited by Interceptor'85; 02-02-2005 at 08:17 PM. |
