Old 01-11-2005, 06:14 PM   #1
niko
likes falcon's
niko's Avatar
Default compression test complete!
Cylinder #1 180psi
Cylinder #2 180psi
Cylinder #3 180psi
Cylinder #4 182psi
Cylinder #5 180psi
Cylinder #6 175psi
this any good? what should i expect for an ED 4litre.
www.carhubsales.com.au
Old 01-11-2005, 06:18 PM   #2
John_LS1
thats way to high for a turbo!
Old 01-11-2005, 06:19 PM   #3
niko
likes falcon's
niko's Avatar
what about with my current setup, with gas and that.
Old 01-11-2005, 07:02 PM   #4
BlOWN-EA
BlOWN-EA's Avatar
no that is all very good readings, constant and still high
No. Of Snapped Axles So Far: 2
BlOWN-EA is offline   Reply With Quote Multi-Quote with this Post
Old 01-11-2005, 08:03 PM   #5
Walkinshaw
Two > One
Walkinshaw's Avatar
compression tests like this are just indictitive are they not, or are they an accurate representation of dynamic compression?
Old 01-11-2005, 10:45 PM   #6
BlOWN-EA
BlOWN-EA's Avatar
ya well they are before the power stroke
Old 02-11-2005, 12:59 AM   #7
wildturkey
wildturkey's Avatar
Thats perfect mate
wildturkey is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2005, 02:58 AM   #8
stockstandard
I did mine the other day and got almost exactly the same, 180+/- 2 or 3
Old 02-11-2005, 02:37 PM   #9
mcflux
mcflux's Avatar
cylinder #6 is always a little low(er) isn't it?
Or am I making things up?
Old 02-11-2005, 02:48 PM   #10
niko
likes falcon's
niko's Avatar
no idea lol i did it twice to see if it was a funny reading and it come up as that again
Old 02-11-2005, 03:03 PM   #11
ned
Once shy... twice bitten
ned's Avatar
Is it hard to do or what? I wouldn't mind sussing mine out, my guess is that it's up sh|tcreek.
The Devil crept into heaven... God overslept on the 7th... the New World Order was born on September 11.
ned is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2005, 03:06 PM   #12
mcflux
mcflux's Avatar
When you do it, don't you pull out the spark plug and put the compression test probe into the spark gap? And then (somehow) hand crank the engine? The gauge then works like a typical pressure gauge and measures the PSI that the cylinder (when piston is at TDC) has in it...
Old 02-11-2005, 03:56 PM   #13
stockstandard
pull the plug out and replace it with guage (also stop fuel from going in - pull pump relay or unplug injector). then crank (not by hand) the engine for about 10 seconds. read the guage. You should also pay attention to how the guage needle moves.
any workshop manual has instructions on how to do it
Old 02-11-2005, 03:59 PM   #14
niko
likes falcon's
niko's Avatar
the tester looks like a pump, twist it into the spark plug hole firmly and all i did was flick it to middle between gas and petrol ehhe
