Old 02-11-2005, 08:53 AM   #1
Vision Zetec
Hurry up Germany!!
Vision Zetec's Avatar
Default Front headlight globes?
hey guys,
Iv seen a few cars at night with very bright blue/white globes for their headlights.
What globes are best for an EBII? (price to performance)
cheers
Daniel
2009 WS Fiesta Zetec 5-Door
Color: Vision
Vision Zetec is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2005, 09:59 AM   #2
gozza
gozza's Avatar
im using the ones you buy from super cheap
i can't rememebr exactly the price cos i have 100 watt high beams and 100 watt normal lights (apparently only for off road use) and the price was a bit more from one to the other...both between 20-40 dollars
the normal lights give off a slight blueish glow but the high beams man are crazy.....if you driveing around hills and moutains they light everything up better than street lights
gozza is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2005, 10:22 AM   #3
The Dok
The Dok's Avatar
Originally Posted by EBII Falcon
hey guys,
cheers
Daniel
Try Philips Crystal Vision or Blue Vision, H4 60/55 I have the Crystal Vision in my car-s & highly recommend them. Do not go above the recommended wattage, as not only will you overheat the wiring loom/s + cause burning of the reflector/s, but more importantly, pi55 off other motorists. Can't give you a price estimate as mine were supplied to me for product testing but a quick internet search should yield results.
_2:
Removed by laminge
The Dok is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2005, 01:13 PM   #4
GenesiS
*Smart *** comment here*
GenesiS's Avatar
_2:
bout $90 for a pair at autobarn... not sure at a place like bursons though... i payed $49 a pair for mine on sale... got lucky, i was most happy... found that the cheap *** super cheap ones didnt last more than a couple of months, the phillips are still going strong, touch wood, and are super bright, they really illuminate the road.
1997 4.0L EL Falcon GLi Sedan Auto
2.5" Cat Back Mandrel Bent Exhaust to Two Lukey Sports Mufflers and a 3.5" Dump Pipe
Lowered all round on King Spring Super Lows
Tinted Windows, Pioneer MP3 Player and Audio System
K&N High Flow Air Filter Mounted in Original Air Box
Trip Computer
NGK Sports Performance Leads
NGK Sports Plugs
Autotecnica Oil Catch Can
GenesiS is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2005, 01:15 PM   #5
gozza
gozza's Avatar
the ones i got from super cheap are higher than 65 watt......ive had them for nearly a year and they haven't blown or melted anything
Old 02-11-2005, 01:49 PM   #6
The Dok
The Dok's Avatar
Too true, the Supacheap one's are rubbish (won't mention brands). Have checked with Autobarn, as of today (2/11/05) they have a sale, how bout that, Philips Blue vision H1-H3-H4 @$54.99. H7 @$69.99. At that price we should stock up!!!
:sm_headba
Removed by laminge
Old 02-11-2005, 01:54 PM   #7
gozza
gozza's Avatar
pffft
Old 02-11-2005, 04:50 PM   #8
Vision Zetec
Hurry up Germany!!
are the EBII normal driving lights H4 or H3?
looks like ill be buying a pair of the philips, get the parkers with them too!
thanks for the info guys
Color: Vision
Old 02-11-2005, 05:01 PM   #9
The Dok
The Dok's Avatar
You'll need H4s for the low/high & H3 (the one's I call a rats tail) for the high beam or grill end of the headlight.
Removed by laminge
Old 02-11-2005, 05:01 PM   #10
BLACK 6
aren't they illegal?
Well to some degree
BLACK 6 is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2005, 05:08 PM   #11
Vision Zetec
Hurry up Germany!!
ok thanks, why do they call the H4 low/high, then also call the H3 high?
H4: high = normal driving light
low = parkers
is that correct?
Color: Vision
Old 02-11-2005, 05:23 PM   #12
GenesiS
GenesiS's Avatar
Well to some degree
nope, blue lights are are, but proper globes aren't...
what is illegal is those that have blue sleeves over them, like blue parkers...
Phillips blue/crystal vision arent actually the same, they are not a sleeve and are not a cheap blue (they dont look like someone stuck celephane over the globe) they are actaully the best globes you can get without going to the expensive european gas globes (cant remeber the type, some one help me out here...).
While they do deliver a crytal white or blueish tinged light depending on which ones you get, they are certainly not illegal.... anyways back to the beer :baby bott
Trip Computer
NGK Sports Plugs
Old 02-11-2005, 09:06 PM   #13
The Dok
The Dok's Avatar
low = parkers
is that correct?
The H4 is a dual filament bulb hence the low/high. The parker is a seperate 5w bulb. The H3 only comes on with high beam.
_2:
Removed by laminge
Old 02-11-2005, 09:09 PM   #14
LUXO_8
windsor user
Well to some degree
we're told by a very reliable source they arent legal, and we dont have to replace them in changeover lights if they've come in blown
and i wish people would listen to the warnings not to use high wattage globes....
please dont come crying when your car wont stop blowing circuit breakers or what not
Old 02-11-2005, 10:37 PM   #15
The Dok
The Dok's Avatar
Well put!!! It never ceases to amaze me that some people disregard all our years experience (in my case 13) with headlights, that they still say crap like........."it's not hurting my headlights" or "I always use higher wattage bulbs (usually on EA-EL) cause my lights are shyte" but don't realise what goes on behind the lens not to mention as has been said in my earlier post, the effect on other road users.
:thebirds:
Removed by laminge
Old 03-11-2005, 10:29 AM   #16
gozza
gozza's Avatar
oh well i'm sure they'll get over it...ull be only blind for a second or two
Old 03-11-2005, 11:13 AM   #17
Vision Zetec
Hurry up Germany!!
but that second or two could be the difference of staying on the road or driving off it!
i had a case where a new european car was driving towards me with VERY bright lights while i was coming out of a bend and i had to shut my eyes for a complete second, lucky i knew the corner well (was near my house!)
Color: Vision
Old 03-11-2005, 11:17 AM   #18
crannersEL
crannersEL's Avatar
Yeah thats what ive noticed, all the BMW ect have these really blue crystal lights that make all the other drivers blind. Its the same with some of the fog lights on the later model falcons and commos.
If these blue vision lights improve the drivers visability then we should all have them.
crannersEL is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2005, 11:34 AM   #19
Clarke AV
OzECruisers Treasurer
Clarke AV's Avatar
100w = burning of the reflector I did
Clarke AV is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2005, 11:40 AM   #20
old_mate
Smash the Boost
old_mate's Avatar
haha now isnt that lovely...not
2023 Hyundai Palisade
1971 Fairmont Sedan
1974 SWB F100
Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
old_mate is offline   Reply With Quote Multi-Quote with this Post
