Old 27-11-2005, 12:16 PM   #1
slamd ef wagon
Default what cam with a 3000 stallie?
gday guys just woundering with u guys that run the jmm3000 what cam did you use as i asked crow and they told me non of there cams would work with a stallie as there power starts at 1500rpm(cams which work with the stock ecu that is)
cheers
AU FAIRLAINE GHIA TICKFORD I6, KINGS SL/KYB ALL ROUND, RED BACK EXHAUST, G220 RIMS
slamd ef wagon is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2005, 01:26 PM   #2
Casper
Contributing Member
Casper's Avatar
If I had a non VCT... I'd actually get the DEV4 JMM cam. It seems to work exceptionally well after 3000rpm. Otherwise some of the more lumpy wade cams would probably be decent too as most of them seem to work in the E series autos but had idle issues that the stall may help overcome.
Older, wiser, poorer.
Old 27-11-2005, 01:46 PM   #3
slamd ef wagon
cheers mate for that advise
Old 27-11-2005, 02:03 PM   #4
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
All the stalling problems in E-Series 6's [And AU's I pressume] with big cams and stock ECU's is from the MAP sensor trying to achieve the target MAP signal, but the cam can only provide slightly lower vacuum, so the ECU has a fit.
What other mods do you have? Any cam where the powerband starts at 2500-3000 will suit the convertor, but not so much the rest of the stock parts on the car.
How do JMM stop the auto going into limp home mode with the 3000 stall?
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2005, 02:16 PM   #5
Casper
Contributing Member
Casper's Avatar
Sorry, wasnt aware that that what the issues were. The AU is different and, with basically no Wade cams really avaliable and the crow cams being pretty much hopeless there isnt a lot of choices for the AU anymore. I am not sure what hamo has but its not JMM, apart from that near on all the AU I6 cars I can think of are running JMM cams anyhow.. and none really have major idle issues.
No idea but, apart from cooking the trans oil but just sitting and stalling at 3000rpm, it never does it. I have only had it go into limphome once and I did it deliberatly but stalling up to 3000rpm and holding it there.. (actually, could stall to 3200rpm, Sprint_ED was with me at the time). As far as I know they just put the stall in and the ECU seems to deal with it just fine. That said the fastest way to launch it (in mine) is to only stall to 1700-1900rpm then flash it to 3000+rpm as you release the brakes.. any higher stall and you seem to just sit and smoke the tyres.
Old 27-11-2005, 03:53 PM   #6
slamd ef wagon
[What other mods do you have? Any cam where the powerband starts at 2500-3000 will suit the convertor, but not so much the rest of the stock parts on the car.
pacy comps,cat,2.5 zorst, hi flow filter, cold air induction, stage 2 shift kit, huge trans cooler
Old 27-11-2005, 04:51 PM   #7
galapogos01
eec tweaker
galapogos01's Avatar
OT, but can I ask how much JMM charge for their stalls, fitted?
galapogos01 is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2005, 04:59 PM   #8
LG
LG's Avatar
Around the $1k mark, that also includes a Oil Cooler.
Hamo is running a Crow Cam by the way. Although he has also got chiptorque and unichip to control it, as well as the hi stall. So he gets the best use out of the Crow cam.
Old 27-11-2005, 05:11 PM   #9
galapogos01
eec tweaker
hmm. i already have a cooler..
the price is offputting, but then so is everyone complaining about limp home mode.
damn cars.
Old 27-11-2005, 05:25 PM   #10
Casper
Contributing Member
Casper's Avatar
damn cars.
I havent had an issue with limphome mode at all.
Old 28-11-2005, 12:53 AM   #11
galapogos01
eec tweaker
i meant with alternative convertors... i know youre a big JMM fan
Old 28-11-2005, 07:50 AM   #12
Casper
Contributing Member
Casper's Avatar
Useless has another sort of stall in his au wagon and hasnt had a limp home issue either. Maybe the AU's dont really have that much of an issue afterall.
Old 28-11-2005, 07:50 PM   #13
Stav
Smile
Stav's Avatar
My stall converter is 3300 stall speed and it is an efficient little bugger.I can stall it from Sydney to Melbourne and not have limp, home until the universal joints snap. I dont know why? On Spiro at autotech engineerings dyno it showed no loss at all.
Old 28-11-2005, 07:56 PM   #14
galapogos01
eec tweaker
what brand is your stall? any more information?
TCE stalls are a hell of a lot cheaper than JMM.
Old 28-11-2005, 10:08 PM   #15
5speedeb
now with 3.73 lsd
do they work as good as the jmm stall?
5speedeb is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2005, 11:18 PM   #16
galapogos01
eec tweaker
for half the price im almost willing to find out.
would love to know what hamo and useless are using. despite people thinking AUs are super high tech, i dont think they will behave all that differently.
Old 28-11-2005, 11:51 PM   #17
Walkinshaw
Two > One
Walkinshaw's Avatar
AaronEF8 has a 2500TCE stall in his car, works a treat and my lord does she get up and boogie. No LHM either.
Old 28-11-2005, 11:55 PM   #18
Stav
Smile
Stav's Avatar
Who is tce? Guys...seriously it was folly and comedy of errors which led me to this converter.Wait and see what it does. Maybe my car has issues like it owner and doesnt go into limp home mode?
Maybe JMM and dominator get better results?
Old 29-11-2005, 12:16 PM   #19
slamd ef wagon
mate please let me no were u have seen tce converters for $300 then cos ill buy one asap!!!!!
Old 29-11-2005, 01:07 PM   #20
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
What brand convertors do JMM paint and re-badge as their own?
Old 29-11-2005, 01:29 PM   #21
Casper
Contributing Member
Casper's Avatar
JMM brand. Its custom fabricated just for them.
Old 29-11-2005, 01:37 PM   #22
Walkinshaw
Two > One
Walkinshaw's Avatar
I think the question's intention was. "Who is the manufacturer of the JMM converters"
Old 29-11-2005, 02:50 PM   #23
Stav
Smile
Stav's Avatar
My converter i from torque converter indutries in Seven Hills. It is good.I asked for a 2500 stall because of fear mongering on the forum and by mistake it turned out to be 3300 stall speed. I suppose they did not count on my engine torque pushing it that high.But it is all heavy duty.I think I paid 330? It cost me 220 to install at j and j performance transmissions in Yennora.
Now I just hope it works on the 1/4
Old 29-11-2005, 04:41 PM   #24
Walkinshaw
Two > One
Walkinshaw's Avatar
Does yours still have lockup, like the Dominator/TCE/JMM converters do?
Old 29-11-2005, 04:54 PM   #25
mcflux
mcflux's Avatar
I am quite interested in this! /me subscribes to thread
Old 29-11-2005, 04:55 PM   #26
Qwikcorty
V8 Turbo Hoon
Qwikcorty's Avatar
these convertors from jmm tce, are they available for the au v8's? would be nice taking off with (when finished) 170+kw and some sticky tyres.
Qwikcorty is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2005, 05:01 PM   #27
24CIT
back to the shop........
24CIT's Avatar
Question
cheers
i'm running a 5000 TCI converter and i had a custom ground cam made by crow cams. though my cam is for a turbo appliction.
Bow to the turbo
24CIT is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2005, 07:16 PM   #28
galapogos01
eec tweaker
ok, sounds like im going to ring TCI then.
im guessing $200-$300 is about normal for a fitting price? given its normally $100ish for a service, and that doesnt involve dropping the trans!
TCE ones go for ~$400 iirc.
Old 30-11-2005, 07:35 AM   #29
slamd ef wagon
i spoke to 2 of adelaides best trans places mv automatics and alltorque converters and they both said the same u cant gor past 2300 2400rpm other wise the limp home mode becomes a problem
Old 30-11-2005, 07:48 AM   #30
dansedgli
dansedgli's Avatar
5000?? Thats a bit high isnt it?
I had a 2500 TCE one in my Turbo AU. It worked fairly well.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
