Old 29-11-2005, 04:18 PM   #1
bakes_eb
bakes_eb's Avatar
Default Thermo fans in eb
hey guys i want to put thermos in my eb, do you guys just put ef/el ones in. also how do yous hook them up i was just thinking of hooking one side onto the fuel pump relay and the other side on a switch.
any help would be great
cheers scott
'93' EB fairmont
5 speed manual.
extractors, high flow cat, 2.5 inch sports exhaust.
Freshly painted in Cobalt Blue.
lowered with ultra lows.
17 inch mags fitted.
Just finished putting a low km el motor in her
bakes_eb is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2005, 04:30 PM   #2
CruizinEB
i think its just a matter of riping the clutch fan and slide the thermos in, but i'm not sure
CruizinEB is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2005, 04:39 PM   #3
Damo
lol ^^ If you don't know then why post ? It's not a matter of just riping the clutch fan out and putting thermos in, if it was then what would power them ?
Bakes - there is a guide on how to do this mod on www.e-series.com.au I think Neb wrote it. That should explain everything you need to know.
Old 29-11-2005, 04:46 PM   #4
bakes_eb
bakes_eb's Avatar
thanx damo i will try find it.
'93' EB fairmont
5 speed manual.
Old 29-11-2005, 05:03 PM   #5
CruizinEB
well tha5t is what i was told, it was easy and all you did was slide the EF-EL ones in and drill some more hols to mount them :P , mind you i was told by some pimple face storeman at an auto store.
Old 29-11-2005, 06:36 PM   #6
RUKIDN
Missing the boost :(
BA XR6 Turbo
301rwkw mild tune
Modified by XR6Turbo Developments
RUKIDN is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2005, 06:44 PM   #7
woodstock_rocks
Yeah, like cruzin'dickwad'eb said, just rip the clutch fan out, and slide the thermo's in.
Oh, and while you're at it, you also need a temp sensor, then a thermal switch to turn the thermo's on when the coolant gets to a certain temp. I haven't done the mod, but i know roughly what's required. I'm sure someone who's done the mod will be more than happy to explain in depth.
Old 29-11-2005, 06:58 PM   #8
CruizinEB
have i said anything bad about you? i dont think so!!!
Old 01-12-2005, 06:13 PM   #9
dazza.b
Default temp sensor
Where can i get a temp/thermal sensor from im just about to do the this weak end but im useing au thermos
dazza.b is offline   Reply With Quote Multi-Quote with this Post
Old 01-12-2005, 07:49 PM   #10
ReGiE
Yeah Rite
ReGiE's Avatar
u can get the thermo switch from super crap or anuwhere. thats where i got mine from.
i used EL thermos they bolt straight in to my EB radiator. ive been told that EF ones are variable speed controlled by the ECU. so they may not work with a thermoswitch
EB2 143rwkw...goone
now riding in MX5 with a little hairdryer on the side of the engine
ReGiE is offline   Reply With Quote Multi-Quote with this Post
Old 02-12-2005, 03:27 AM   #11
BoZZa17
Lovin the Manual.
BoZZa17's Avatar
they all work.
even au ones
and yeah get one of them universal thermo switches from autobahn with the little copper bit u tweak into your top radiator hose.
then use that to earth the power to the thermo fans when it gets to the desired temp (like 96deg or somethin)
BoZZa17 is offline   Reply With Quote Multi-Quote with this Post
Old 02-12-2005, 08:09 PM   #12
snypereb
[EBGLT]
snypereb's Avatar
Do you have to have the sensors?
[EBGLT]
Old 03-12-2005, 08:22 AM   #13
Papa Smurf
Papa Smurf's Avatar
Yes you do or the Fans will not work? You could just wire them up and have them going ALL the time but that would defeat the purpose.
Papa Smurf is offline   Reply With Quote Multi-Quote with this Post
