29-11-2005, 09:19 PM | #1 | ||
Hey guys! this is my first thred here and wondering if you can help. Im 17 and just bought an ED XR6, 5 Speed in cobolt blue. so far its really good. i only have 1 complaint. my clutch. i dont know if my clutch is meant to be real heavy, its like pushing down on a brick. is that normal for one of these cars? is there any way to make the clutch feel more softer, maybe change the clutch cable?? Any feedback is welcome, thanking you in advance. Tim.
29-11-2005, 09:21 PM | #2 | ||
There is a good chance the clutch cable is stuffed.
Check the firewall where the clutch cable goes through because it is prone to tearing when this happens. |
29-11-2005, 09:22 PM | #3 | ||
there's a good chance the cable is stuffed. It's a bit of a common problem, the cable cuts into the casing making it hard to move. Pull the cable out and slide it with your hand, it should move freely. If not, replace the cable.
Another problem could be a cracked pedal box or firewall, making the clutch go in on a slight angle.....although if that's happened you'll usually hear a clicking or cracking sound when you put the clutch in cause the broken metal will rub against itself. |
29-11-2005, 09:26 PM | #4 | ||
The cable coming out of the firewall does not move freely, its hard to move by hand... when i press the clutch, its squeeks though, but doesnt sound like its creeking or cracking ( sometimes its hard to distinguish a squeek from click ). thanks
30-11-2005, 02:44 AM | #5 | ||
Rider on the storm
There's a good chance the clutch itself is stuffed.
My EA had the same problem, had to push the pedal right into the firewall, even then it didn't disengage properly (reverse always grinded). Replaced the clutch cable (half-melted from the extractors)- didn't do anything, decided to replace the clutch with a PBR Perf. clutch and realized the old clutch had two or three hotspots and half the arms were broken. Works nicely now. |
30-11-2005, 10:49 PM | #6 | ||
GRRRRRR
I had the same problem with mine.
Replaced the clutch and clutch cable and it lightened the pedal a fair bit. The clutch in mine was completely stuffed and the pedal was very heavy when i first got the car.
FPV XR OWNERS CLUB OF VICTORIA ED XR6-polynesian green,factory 5 spd manual,factory electric sunroof,momo wheel,cruise control,custom plates. |
01-12-2005, 01:03 AM | #7 | ||
its not a!
I had the same thing, welded up a new bracket on the firewall. Got a new cable and shes all shweet!
The clutch cables when at their best are still fairly heavy, you get that...have to live with it (Form massive left calf muscles)
-93'ED XR8- 5-spd Charcoal Black ohh yeeah
01-12-2005, 01:09 AM | #8 | ||
my clutch in my AU was very heavy when i first got the car... and i left it for a year like this.. and then the clutch finally gave way, got it replaced with a heavy duty clutch and it was lighter than the stock one.. i also found out that the firewall was cracked along the peddal box...
easy way to tell.. get a hose and poor water on your windscreen infront of the drivers side.. if water leaks into the drivers floor when you press the clutch then you too have a cracked firewall or pedal box.. |
01-12-2005, 01:12 AM | #9 | ||
its not a!
I could see where my firewall collapsed and the cable had heaps of movement, welded a plate there..The cable then snapped because it was worn in such a way the when engaged it was strangling itself, to the point of major snappage
01-12-2005, 03:06 PM | #10 | ||
when i bought my eb xr6,ef gli and ef xr6 all had the same problem the cables were cracked replace the cable and it will fix the problem
01-12-2005, 07:20 PM | #11 | |||
Yeah i had exactly the same problem with my ED. i just replaced the clutch and then the cable and now the whole thing works beautifully... Good luck with it mate. Steve |
01-12-2005, 07:27 PM | #12 | |||
XB in parts...
02-12-2005, 06:37 PM | #13 | ||
its bascially all manual fitted cars up till AU, ba's dont have this problem..
the metal on the firewall is just simply too think, and flexes every time you push the clutch.. and over time the flex becomes a weak spot where it cracks... just about everyone i know with a manual falcon has had this problem... |
02-12-2005, 08:08 PM | #14 | ||
02/90 EA II Fairmont
my turn
211RWKW EA |
