Old 29-11-2005, 11:26 PM   #1
snypereb
[EBGLT]
snypereb's Avatar
Question Oil
Hey guys after driving around on the weekend thought i would check my levels and i have like a bit of oil on the front of the engine. Only thing is that my oil level was still the same as it was before i left. Whats going on here?
[EBGLT]
Old 29-11-2005, 11:29 PM   #2
John_LS1
um, you lost no oil??? the amount that came out didnt register on the dipstick? you parked on a slant affecting oil reading? dont sound like you should worry about it...
Old 29-11-2005, 11:33 PM   #3
snypereb
[EBGLT]
snypereb's Avatar
Na probably not when is the best time to check the oil though? I know when your checking the tranny it needs to be hot. Normally just check it when the car is on my front lawn and its pretty flat.
[EBGLT]
Old 30-11-2005, 09:24 AM   #4
FNQracing
RAGE Engineering
FNQracing's Avatar
Check you oil on level ground when the engine is cold (preferably). If its hot, wait a good 10-15mins for the oil to run down into the pan. Pull out the dipstick, wipe it, re-insert it, then take it out for an accurate reading.
If it doesn't fit, use a BIGGER hammer
FNQracing is offline   Reply With Quote Multi-Quote with this Post
Old 30-11-2005, 10:00 PM   #5
snypereb
[EBGLT]
snypereb's Avatar
Sweet mate thanks ill do it first thing in the morning!
[EBGLT]
