Old 01-12-2005, 08:50 PM   #1
Terror6X
Formerly eawags
Terror6X's Avatar
Default Best stock exhaust manifold?
Are all the same or do they differ and which one is the best?
Do the BA exhaust manifolds fit the single OHC? If it does this would be the best flowing item wouldnt it?
Terror6X is offline   Reply With Quote Multi-Quote with this Post
Old 01-12-2005, 08:53 PM   #2
Rmyers
Does Steve have a car?
Rmyers's Avatar
Pretty sure all the exhaust manifolds on the OHC engines are the same. I believe the BA's have oval shape exhausts ports so i don;t think they will work on an OHC...
AKA Mr Silver
Chasing reliability....:
"When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
Rmyers is offline   Reply With Quote Multi-Quote with this Post
Old 01-12-2005, 08:57 PM   #3
jonbays
TL40 Wagon?
they are all the same on E-A series and BA won't fit get extractors
Old 01-12-2005, 08:58 PM   #4
Perana
Perana's Avatar
EA - AU were the pretty much identical.. the only difference being a couple of mounting lugs are missing from the later ones.
Perana is offline   Reply With Quote Multi-Quote with this Post
Old 01-12-2005, 09:22 PM   #5
Psycho Chicken
Psycho Chicken's Avatar
Actually they aren't all the same. EF2/EL Ghias are the worst of the lost, the rest are the same though.
Old 01-12-2005, 09:31 PM   #6
Polyal
The 'Stihl' Man
Polyal's Avatar
strange that the ef/el ghia were the worst then, with the tickford engine you would have thought they would put the best on.
Or maybe they wanted to keep the power down a few kws
  • 1973 ZF Ford Fairlane
Old 01-12-2005, 09:47 PM   #7
Psycho Chicken
It's because of the extra sound deadening they put in them. Hence the Ghias have 162kw and the XRs have 164.
Old 01-12-2005, 09:50 PM   #8
EFFalcon
Last warning
EFFalcon's Avatar
i thought the difference between XR and Ghia was the cat back, not the manifold?
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 01-12-2005, 09:51 PM   #9
Casper
Contributing Member
Casper's Avatar
Same applies to the AU ghias. Something to do with sodium sound deadening in the actual manifold itself.
Older, wiser, poorer.
Old 01-12-2005, 09:53 PM   #10
Terror6X
Formerly eawags
Terror6X's Avatar
Whats the most horsepower and 1/4 time people have seen with stock exhaust manifold?
Reason for this is im considering putting a 3.9OHC in my XF and most extractors dont fit and arent needed. 160fwkw is a good enough stepup and 180fwkw would be great with 2.5inch exhaust, cam and holley.
Old 01-12-2005, 09:54 PM   #11
NZ
NZ's Avatar
Who would have thought ehh?
Old 01-12-2005, 10:15 PM   #12
64compact
try useing the two back halfs of the manifold and run the extra front eng pipe but you have to block off the join section. a little machining and a good fitting plug will do and you will get away from that stupid little opening just after the front section joins the back, and efectivly you have a set of headers, on the EA-EF you run the front pipe around the steering coupling which you wrap to keep kool. have a look ?? it might suit you and it is as cheap as chips.
64compact is offline   Reply With Quote Multi-Quote with this Post
Old 02-12-2005, 09:36 PM   #13
Terror6X
Formerly eawags
Terror6X's Avatar
With the right cam and exhaust does anyone think 180kw can be had like the twin cam?
Old 03-12-2005, 12:05 AM   #14
fordboy1981
fordboy1981's Avatar
what a great idea, now why didn't I think of that?!
Dave.
Originally Posted by bathurst77
I would rather it was on tv than not on and replaced by a show in Bognerslavian about a dead fish who solves crimes. Tho being SBS some girl may take her kit off for no reason at any time.
fordboy1981 is offline   Reply With Quote Multi-Quote with this Post
