03-12-2005, 05:14 PM | #1 | ||
hey just wondering how do you remove the water pump pully i thought it was a hex key like the power steering but the it aint any info would be great need urgent help cars in peices cheers guys
http://i11.photobucket.com/albums/a1...50/cartoon.gif |
03-12-2005, 05:18 PM | #2 | ||
what car is it?
03-12-2005, 05:21 PM | #3 | ||
ef falcon 6 cylinder
03-12-2005, 05:33 PM | #4 | ||
Last warning
when we've done it we used a pully puller kit, or a press.
press made it really easy :P
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
03-12-2005, 05:39 PM | #5 | ||
but on the inside of the new pump there is a thread i just couldnt see it being pressed cause you need to get the pully off to be able to get the pump off
03-12-2005, 06:19 PM | #6 | ||
you dont need the pulley off to take the pump out.
I just got a new pulley with the new pump ($10 extra) and pressed that on. |
03-12-2005, 06:25 PM | #7 | ||
Last warning
i've never taken the pully off to take the pump off.
03-12-2005, 06:45 PM | #8 | ||
well i deffinatly cannot get the socket on properly cause the pulley is in the way
03-12-2005, 06:56 PM | #9 | ||
hibernating
you can get the waterpump off using spanners
03-12-2005, 07:06 PM | #10 | ||
got it bastard of a thing also the metal peice that goes into the back of the pump hows that come out? i dont wanna force it does it just slide out
03-12-2005, 07:23 PM | #11 | ||
hibernating
yeah it just slides out, its most likely just stuck from silicone
03-12-2005, 08:42 PM | #12 | ||
Sometimes with aftermarket pumps they don't come with a pully. Ford has a special tool for removing and installing the pully. They are just a press on fit as others have said. the problem with the plastic ones is they tend to shatter when being pulled off.
