Old 21-12-2005, 09:14 PM   #1
Jason[98.EL]
Jason[98.EL]'s Avatar
Default help with programing smart lock
gday all
as the title says i need help to program a smart lock controller on my el
any help would be great
thanx jason
[SIGPIC][/SIGPIC]
Old 21-12-2005, 09:18 PM   #2
wang peterson
fordmods has a doco on this, search their site.
Old 21-12-2005, 09:24 PM   #3
BABOSS
BABOSS's Avatar
Check your manual if you still have it, it involves pressing the door lock/unlock button a number of times to program the remote.
BABOSS is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2005, 09:27 PM   #4
InitialD
Low and Loud
InitialD's Avatar
Ahh its ok you remided me of the wrong person
Old 21-12-2005, 09:28 PM   #5
wang peterson
It actually involves something along the lines of pushing the rear demist button, and ignition on or something. I don't think you touch the door button..
Old 21-12-2005, 09:32 PM   #6
wang peterson
Answer:
Adding and Removing remote Keypads to the Smartlock module (EF/EL)
Up to four Keypads can be programmed and used with the Smartlock Remote Central locking system.
If you have replaced the BEM, or new keypads are being added to the system, you will need to train the keypad codes to the module.
# 1. The ignition switch should be in the Off position, with all the doors shut and Unlocked.
# 2. Turn the ignition key to the ACCESSORY position and within 5 seconds, operates the rear demister switch exactly three times in quick succession. (IE. Press the switch so the Demister light turns on, then off, then back on again.)
# 3. After the 5 seconds is up, the door locks will change state, to indicate that the BEM has entered keypad learn mode.
NOTE : All existing keypads at this point, have been erased from memory !
# 4. Press either buttons on the keypad that is to be trained. The door locks will change state twice, to indicate that the keypad has been added to the BEM memory.
# 5. Follow step 4. for each keypad that is to be added to the BEM memory. A maximum of 4 keypads can be added to the BEM memory.
NOTE : You must teach all remote keypads for the Smartlock module, before proceeding.
# 6. When you have taught all the remote keypads, turn the ignition to the Off position to leave the learn mode. The door locks will change state to indicate a return to normal mode.
# 7. Check the function of both buttons on each keypad, to ensure that the keypad has been trained.
Old 21-12-2005, 09:53 PM   #7
Jason[98.EL]
all fixed thanx to wang peterson great info
jason
mods please remove this thread
jason
[SIGPIC][/SIGPIC]
Old 21-12-2005, 10:34 PM   #8
wang peterson
heljas, why remove the thread? it can be used as a resource for other people later down the track when they search something.
Old 21-12-2005, 10:41 PM   #9
Jason[98.EL]
more so to save space on the forums im about to save it for future reference
but if you think i should leave it i will
[SIGPIC][/SIGPIC]
Old 10-06-2020, 10:05 PM   #10
francoisoroode
Default Re: help with programing smart lock
Can you remove the smartlock system?
francoisoroode is offline   Reply With Quote Multi-Quote with this Post
