Old 22-12-2005, 04:15 PM   #1
elusiverunner
elusiverunner's Avatar
Question Squeaky Brakes
Please people I really need some help as this problem has now been with me for 12 months and I am getting so close to putting a match to the car:evilsasmo I have a 1991 Fairmont Ghia that is quite a good car apart from a squeak in the front passenger side brake.
Now before you ask I have been taking the car over to a brake specialist. The rotors have had a very slight machining as they were new. I have had two change of pads - different compounds; calipers have been overhauled - twice; slides have been lubed everything connected with this brake has been serviced yet the squeak still goes on.
When ever the car is in motion the squeak starts - tapping the brake pedal causes the squeak to be louder, more of a squeal, momentarily and then it returns to how it was originally. I have cleaned the brakes, etc with brake cleaner and sprayed the approprite parts with anti-squeal, and the pads have had anti-squeal; anti-squeak applied to them.
Any ideas would be most appreciated - especially if it fixes the problem.
elusiverunner is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2005, 06:04 PM   #2
EA2BA
PM me if you want
EA2BA's Avatar
there should be 2 thin metal pad locators either side of where the brake pads sit into, are they present, i understand they are supposed to prevent brake squeal.
most dont see them as important, and with or without them you may not get a squeak, so your specialist may not have mentioned or noticed they are not there.
Old 22-12-2005, 09:10 PM   #3
BABOSS
BABOSS's Avatar
Have you tried replacing the wheel bearing and ruling it out?
BABOSS is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2005, 12:40 PM   #4
steven95falc
If ytou need wheel bearings sing out i can help you out for bout 10 bucks for both sides with seals if you can pick em up im in melb
steven95falc is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2005, 12:48 PM   #5
fairmont1998
fairmont1998's Avatar
Try chucking the car on stands and spraying a little silicon spray onto the rotor rear seals. Believe it or not, these can squeak. Took me ages to find it....
Current Rides:
2012 KK Jeep Cherokee Limited CRD - Still going strong
2019 MG ZS Essence
1988 RD Mitsubishi Colt GL - 59kW of Fury
2022 Kia Stinger GT
fairmont1998 is offline   Reply With Quote Multi-Quote with this Post
