Old 14-01-2006, 09:27 PM   #1
LTD boy
LTD boy's Avatar
Default lsd oil change??
Bought some oil for the LSD today found the filler plug, so how do get the oil out first
LTD boy is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2006, 09:30 PM   #2
klawsterfobik
Bad Music and Litre Bikes
klawsterfobik's Avatar
undo the bottom most bolt Thats the drain plug, as well as securing the back of the housing to diff case.
IF that doesnt work (it will), just undo the bottom one completely, and then the next one on both sides a little less that all the way, and then the next one on both sides a little less.. and keep going til its loose enough that you can lever the back out a bit without bending the plate. Have the oil tray ready as it will come out thick and FAST
XY Wagon - NAKED!
Originally Posted by Gammaboy
Anyway. Enough reality, back to the topic.
klawsterfobik is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2006, 09:32 PM   #3
LTD boy
LTD boy's Avatar
cheers i'll give it go tomorrow
Old 14-01-2006, 09:49 PM   #4
mcflux
mcflux's Avatar
sw33t, and here I was thinking you have to crack open the whole damn housing (every bolt!) to let the gooey goodness out.
Old 14-01-2006, 10:02 PM   #5
Damo
well it's best to remove the cover plate completely once it's draned and replace the gasket.
Old 14-01-2006, 10:11 PM   #6
mcflux
mcflux's Avatar
*ignore this post*
Last edited by mcflux; 14-01-2006 at 10:16 PM. Reason: made comment without thinking. Waste of a post!
