Old 21-01-2006, 11:41 AM   #1
ea007
Default timing marks on cam and crank need help
warped the head on my ea need help with timing marks on crank and cam chain slipped
ea007 is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2006, 04:20 PM   #2
naughtyfalcon
you'll need to remove timeing cover while head is off and realign them , they have marks on them, good luck
2000 AU Wagon
naughtyfalcon is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2006, 04:50 PM   #3
Damo
I too am curious about this as i'm putting a motor together, how are they aligned ? If the motor is at TDC, the mark on the cam gear sits about 3mm above the head or something ?
If anyone could give a detailed write up of what to do including the tensioner etc that would be great.
Old 22-01-2006, 03:17 AM   #4
Brent79
yep thats right, at TDC, the cam gear notch will be at the 3 o'clock position. I dont use timing marks as they are often out or wrongly set. Its better to just remove the rocker cover, remove #1 spark plug and shove a 30cm wire rod down the hole to find TDC for #1. U can find it by watching the valves for that cylinder. Dizzy cap should be off also so that ign timing is on the correct stroke!
Brent
EB1 Falcon Wagon
3.9L Multipoint with 5 speed manual
Pacemaker extractors & 2.5" Redback exhaust
Tickford Head and Wade 1004 cam
HP4 Chiptorque chip and XH intake
1992 DC LTD
5LTR DUEL FUEL
Brent79 is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2006, 11:44 AM   #5
ea007
found chain hadnt slipped np thanks for the replies
