meow
With the weather currently above 40 degrees here and I'm sure in other places around Ausrtalia I was wondering if anyone has had any problems thus far?
Climate control on in mine (NC V8, set at 16 degree) and cruising along at 80k it was sitting up halfway and occasionally sinking down a bit further/cooler. So I'm pretty happy with that.... Also, going around 50/60k it will drop into LHM and stay there till the speed is increased, this is normal to try and cool the trans and engine (as per owners manual). Any one else experiencing this, and would fitting a larger trans cooler prevent this happening? |
windsor user
mine doesnt like having the AC on, temp sits about where you said yours is, maybe a bit higher...
so im converting to thermo's. |
351 cubes of power
hits 40 plus here too...the old xf ute is handling it well but i don't have a/c to push it a little more...damn...need new car!
:sm_headba NO RICE AND NO RAP :sm_headba |
My clutch fan goes nuts in this wheather, sounds like a jet plane taking off. It works great though and car stays at a constant temp even when giving it a bit of stick. Only reason I would ever convert to thermos would be for the noise factor.
