Old 24-01-2006, 01:01 PM   #1
bab
Default Ef 11 Temp Gauge Reading
Under Normal Summer Driving Conditions My Temp Gauge Eventually Rises To Half Way Between The Normal Setting With Pointer On The "r" Of Normal,is This Quite Normal Or Should Gauge Read A Lower Reading,also I Cant Tell If The Fans Come On At This Reading,any Help Would Be Appreciated Bab
bab is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2006, 01:19 PM   #2
EA2BA
PM me if you want
EA2BA's Avatar
if it is always steady at the same spot when you drive the car, then dont worry, it is fine, if it doesnt head toward red then dont panic.
just open the bonnet after it gets to normal temp the fans will be able to be heard if they are running, they are a little noisy.
Old 24-01-2006, 01:50 PM   #3
fiery
fiery's Avatar
Mine often sits in that area and its apparently very normal and fine to be there as long as its doing it regularly... mine only does it during hot days otherwise sits lots lower...
I'm sure the 1 & 2 series would have to be similar.... but could be wrong :newangel:
fiery is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2006, 01:53 PM   #4
EFFalcon
Last warning
EFFalcon's Avatar
it should highly depend on the type of driving you're doing.
mine sits in the same area unless its a bit cooler and its freeway driving etc.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 24-01-2006, 03:01 PM   #5
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
Mine does the same on hot days as well, as long as it stays in the 'normal' section, it'll be fine.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2006, 03:08 PM   #6
bab
Default eased my mind
many thanks for replies,eased my mind ( or is that head ) bab
Old 24-01-2006, 09:53 PM   #7
EBIIBurner
EBIIBurner's Avatar
my dads car runs on that has since he got it EF and never gone above the R on normal
EBIIBurner is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2006, 10:30 PM   #8
MightyXR6Turbo
Boooostn'
MightyXR6Turbo's Avatar
Yeah my EF is exactly the same... the R/M spot on Normal must be where the ECU throws on more fanspeed to regulate it and leave it there... That was the hottest it got when I was driving up steep hills in the 40+C we had in SA over the weekend.
2012 FPV GS Ute - Kinetic, Supercharged 5.0L, 6spd ZF auto, leather interior - The Boosted Daily!
1979 XD Fairmont Ghia - Silver, 302C V8, Full velour interior, slowly building her up to be a tough cruiser!
2002 Nissan Patrol ST - Desert Gold, 4.8L DOHC 6cyl petrol (Soon to be reequipped with a 5.7L LS1 V8), 5speed auto, lifted, locked, 33's, nature destruction vehicle!
MightyXR6Turbo is offline   Reply With Quote Multi-Quote with this Post
