31-01-2006, 10:12 PM | #1 | ||
BF F6, APV SR3900
someone please explain to me what the story is with heads and bottom ends (3.9 and 4l) i know about mpfi etc...
im just tossing up which way to head towards.. i dont want to have to modify anything ecu or clutch related etc.. just basically in and out swap... whats the way to go? ea head ok? ea botom end ok? someone sort the rubbish for me please..
Santo White APV SR3900 [WIZZRD] (Click Here) [/COLOR] Daily: 2006 Red BF F6 Typhoon Bluepower enhanced. |
31-01-2006, 10:22 PM | #2 | ||
now with 3.73 lsd
if u can find one a late el head 96da on a ef-el bottom end should do the trick
31-01-2006, 11:14 PM | #3 | ||
got an EF head if your interested.. PM me for more details
31-01-2006, 11:33 PM | #4 | ||
Ok 3.9 had deeper dish on the pistions and smaller chambers on the heads
4.0 had less dish on the pistion and larger chambers on the heads. 3.9 head + 4.0 bottom end = incressed compression 4.0 head + 3.9 bottom end = Decressed compression The blocks are the same the 3.9 had a slight over bore to make it a 4.0 |
31-01-2006, 11:52 PM | #5 | |||
Low and Loud
"caarrrn the 3.9"
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon : |
01-02-2006, 02:01 AM | #6 | ||
BF F6, APV SR3900
hrmmm... apv didnt have any engine mods as such (def not bottom end)
i think i can get away with just doing a sump gasket without removing engine for now.. hrmm
01-02-2006, 12:12 PM | #7 | ||
meow
I remember talking with a guy who raced an EA saloon car.
Apparently the EA heads had about 8 different castings, the 'better' ones (for cooling I think it was) where found on late '88 or late 89'models... |
01-02-2006, 12:23 PM | #8 | ||
PM me if you want
i have this, plus a slight deck on the head and bloc plus an AU head gasket yet to start the car, but getting closer every day
01-02-2006, 12:53 PM | #9 | |||
01-02-2006, 01:20 PM | #10 | ||
Last warning
are you sure the EA heads have smaller chambers?
i was told despite the little seperator in the chamber, the rest of the chamber was actually bigger. we need someone to go and CC all the heads :P
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
01-02-2006, 02:44 PM | #11 | |||
01-02-2006, 03:44 PM | #12 | |||
PM me if you want
01-02-2006, 05:43 PM | #13 | ||
BF F6, APV SR3900
mine is a late '89... so if i wanted to keep my head, what would be a good block to screw it to? much difference at all or just do seals and ИИИИ on mine?
i don't understand the theory behind compression except that for a forced ind. motor lower compression is better.. so do i want inc. comp or dec. comp? and what exactly goes harder?? a 4 or a 3.9? the ea 5spd was fastest wasnt it, or was that purely due to weight? my mods: wade 977b, crow valve springs, extractors... pretty plain and simple stuff... i just did cam and stem seals and springs, so id like to keep my head... thought i had a bottom end rattle.. turned out to be new thrust bearing already making noise... how would i know if my current bottom end is a bit iffy? would i just be better off changing sump gasket seal and putting a chip on it? p.s. i also have a complete 3.9 cfi sitting around... thanks all!
Santo White APV SR3900 [WIZZRD] (Click Here) [/COLOR] Daily: 2006 Red BF F6 Typhoon Bluepower enhanced. Last edited by santoitaliano; 01-02-2006 at 05:48 PM. |
01-02-2006, 08:21 PM | #14 | ||
EF-onwards bottom ends have better counterweights or something like that for better balance and rpm.
I think. Can someone confirm this? |
05-02-2006, 03:24 AM | #15 | ||
BF F6, APV SR3900
so do i want a 3.9 head on a 4l block? is higher comp what i want?
