Old 31-01-2006, 10:47 PM   #1
blwneb
come join me
blwneb's Avatar
Default blwneb has now blwn headgasket
got power on tap, you have to use it, and that i did, anyone no what a good headgasket to use.
ID RATHER BE BLOWN
blwneb is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2006, 10:50 PM   #2
EF_Frmnt
EF_Frmnt's Avatar
Get a steel one out of an AU.. much stronger and will lower your compression ever so slightly over the cardboardy ones. Also get au head bolts they have a bigger shoulder on the top of the bolt and are stronger
EF_Frmnt is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2006, 11:20 PM   #3
Gunns
Gunns's Avatar
The steel Au one will increase compression as it is 20thou thiner than an Eseries one. With boost I would be looking at a ACL decompression gasket. You can order them in diffrent thicknesses to suit your boost application.
Gunns is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2006, 04:51 PM   #4
blwneb
come join me
blwneb's Avatar
I dont want to decompress that much, as if i take off supercharger might loose power, will the au headgasket be more durable, what, are other options, to stop this from happening again.
ID RATHER BE BLOWN
Old 01-02-2006, 04:56 PM   #5
4.9 EF Futura
Official AFF conservative
4.9 EF Futura's Avatar
All in the tune!
A cup half empty... but full of euphoria.
4.9 EF Futura is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2006, 06:56 PM   #6
blwneb
come join me
blwneb's Avatar
Well my car runs a 9psi powerdyne, took the head off and yep number 6 cylinder was the problem, the chamber had got to hot and the side of 6 cylinder, the gasket bowed and split abit, so i have told the people checking the head, and they are going to look into a headgasket for the application, take it from me, if you have forced induction, always have the fuel to cope with the heat, do not let it lean, i will be connecting the rising reg, and fuel pump, and before i put the belt back on, will be getting it tuned.
ID RATHER BE BLOWN
Old 01-02-2006, 10:01 PM   #7
INJECTED_250
Custom user title
INJECTED_250's Avatar
Au head gasket will love boost.... You will melt a pistion before u melt an au gasket :>
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2006, 10:06 PM   #8
blwneb
come join me
blwneb's Avatar
Why are the au head gaskets good for boost, i was just running a standard gasket before
ID RATHER BE BLOWN
Old 01-02-2006, 10:17 PM   #9
The Goodz
E-Series Firemaker
The Goodz's Avatar
AU gaskets are steel and are far more durable. Part of the reason so few AUs ever blew headgaskets. As for head bolts, Ford doesn't sell anything other than the AU bolts. Part # AU6564A from memory...
Alex
The Goodz is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2006, 11:13 PM   #10
blwneb
come join me
blwneb's Avatar
but are the au headgasket good for forced induction, has anyone done this
ID RATHER BE BLOWN
Old 01-02-2006, 11:32 PM   #11
EFFalcon
Last warning
EFFalcon's Avatar
ea ba turbo is running 2 AU headgaskets.
Not sure what torque settings they're using though.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 02-02-2006, 02:33 AM   #12
EDXR8
EDXR8's Avatar
IMO use a standard ford gasket or maybe an ACL or similar graphite gasket, and make sure the head is nice and straight, head bolts are torqued to spec and the engine is tuned properly. If these things are done properly, there is no reason for a head gasket to blow, especially with a powerdyne.
Steel gaskets are very strong and will hold up to boost but the problem with that if the tune is out, instead of a head gasket blowing you will melt a piston instead. Head gaskets are a safe failure point, I would much rather change a head gasket then rebuild a bottom end.
EDXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2006, 05:24 PM   #13
blwneb
come join me
blwneb's Avatar
yeh thats a good point
ID RATHER BE BLOWN
Old 02-02-2006, 07:01 PM   #14
Walkinshaw
Two > One
Walkinshaw's Avatar
Exactly what you DONT want.
I'd be using a stock ACL EA-L head gasket as insurance.
...how to stop it happening again. Get a decent tune and it will be peachy
Old 02-02-2006, 07:40 PM   #15
CHEF
Yeah the stock gaskets are fine as long as you get it tuned well, ie no detonation at all.
Ive done a good 10 000kays with 15psi and havnt blown the headgasket,a good tune is the key to keeping these motors alive and reliable.
FG G6ET RAPIDTuned, RAPID V1 IC, F6 turbo.
FG2 GT RAPIDTuned on E85, Xforce exhaust.
CHEF is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2006, 05:57 PM   #16
blwneb
come join me
blwneb's Avatar
yeh i thought so, i was meant to get it tuned but i was slack, i know it was running lean but when you got the power on tap, and someone pulls up next to you, you forget, and exactly what happened.
ID RATHER BE BLOWN
Old 03-02-2006, 07:45 PM   #17
CHEF
LOL, that quote should be a sticky
Old 03-02-2006, 09:20 PM   #18
TURBOTAXI
Turbo Falcon Fiend
TURBOTAXI's Avatar
I think someone already said it, but two AU gaskets would have to be a good thing?
TURBOTAXI is offline   Reply With Quote Multi-Quote with this Post
