11-02-2006, 08:46 PM | #1 | ||
My Ed Xr6 wont start, The Sparky was putting a line in for a invertor ( cutting into the radio harness) and now the car wont go please help
11-02-2006, 09:00 PM | #2 | ||
hmmm boost
there are 2 green and yellow wires that go to the battery behind the stereo ,he's prob only hooked one of them up ,they both need to be hooked up as one of them goes to smartlock ,so ifs its not hooked up it wont start man so try that
EL TURBO GHIA GT3582R WOLF3D TUNED BY JEM |
11-02-2006, 09:12 PM | #3 | ||
Monty I can only find one wire, the bloody sparky cut and ran before I started the car
11-02-2006, 09:30 PM | #4 | ||
Will the Car turn over if the smartlock is broken?
11-02-2006, 10:06 PM | #5 | ||
Two > One
yes it will turn over, you wont have any fuel/spark though
11-02-2006, 10:12 PM | #6 | ||
hmmm boost
it will turn over but wont fire .there should be 2 green wires with yellow trace ? if there isnt then check all your fuses lpt 10 amp one its red i think .does your intirea light work
11-02-2006, 10:18 PM | #7 | ||
The interior light wont work and the radio is really low on power
11-02-2006, 10:35 PM | #8 | ||
hmmm boost
is ya battery flat ??
did you check or fuses ??
12-02-2006, 03:09 PM | #9 | ||
The battery is on 11 volts and the fuses (the ones I can find) are fine
12-02-2006, 04:54 PM | #10 | ||
look at ur old pod cheak were ur constend wire is ther should b 2 green with yellow wires going in ther so i u see two wires in the old pod then the others gots to b arouns some were
plus u have to reprogram ur smart lock leave ur ignition on for 30-45 mins then it should kick over turn off then try turnig over again if it dosent then u dont have ur conseten wire for ur smart lock wired in witch is green with yellow thru it i would no coz i did the same thing:P |
12-02-2006, 07:10 PM | #11 | ||
Its gone V
11 volts is a bit low should be bout 12.4 with the car off...have you also tried to hit the dash over the heater controls. then start it or hold the key to start pos. then hit the dash and then you will know if it is that.
my mates got that problem one ED I6 and EF XR8.. |
12-02-2006, 09:19 PM | #12 | ||
Which module is the smartlock? The orange one? The only Green and yellow Wires I can see is one for the radio and one for the glovebox light
13-02-2006, 12:22 AM | #13 | ||
V8 Ghia & BF2 XR6 + Wagon
Had same issue once & fuses looked fine.
Replaced some and it fixed the problem.
Windsor now harmonically balanced for EARTHQUAKE free driving!: |
13-02-2006, 11:05 AM | #14 | ||
rofl copter
grab a test light and test the fuses that way, but im pretty sure itll be that wire. altho i have a green/yellow floating around in mine but my car still starts? but ef might be different, they might have tapped into the loom back a bit, who knows
GQ patrol.
.... thats all |
