Old 12-02-2006, 11:24 AM   #1
Vash
Default What maintenance?
Hey all.
I just got a 94' ED with 120,000kms, but no service history.
What servicing should i do? I know the timing belt hasnt been done yet.
Cheers.
Vash is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2006, 11:28 AM   #2
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
well for a start there is no timing belt it is a chain and doesn't need to be replaced!
change the oil in diff trans engine. change oil, air filters
BLUEPOWER RACING DEVELOPMENTS
Strive for perfection in everything we do. Take the best that exists and make it better.
When it does not exist, design it. Accept nothing nearly right or good enough.
-[BLKPHN] (VIC) PLATES FOR SALE $495.00-
BLKPHN is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2006, 01:29 PM   #3
Vash
Thanks.
Also, its a dual fuel and auto.
What oil do i put in on an LPG? I heard you need different stuff. And its ok to use petrol with LPG oil?
96' Ford Falcon EL
Old 12-02-2006, 03:59 PM   #4
TURBOTAXI
Turbo Falcon Fiend
TURBOTAXI's Avatar
Yeah, just get an oil that is specified as an LPG/Dual fuel oil.
Yes you can still use the petrol, but I guess you wouldnt be using it much.
I agree with the above, when I get a new car I go through it and do filters, fluids, plugs and leads. At least you know THEY are OK then.
Just a few.
TURBOTAXI is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2006, 04:04 PM   #5
Vash
One more thing, the previous owner said i should use petrol every 3rd tank of LPG, is this true? Or can i just use LPG all the time and leave alittle petrol in the tank?
96' Ford Falcon EL
Old 12-02-2006, 04:59 PM   #6
TURBOTAXI
Turbo Falcon Fiend
TURBOTAXI's Avatar
Mate up to you.
If you want to keep your injectors healthy, you need to put some fuel through them every now and again.
The other side to this is you dont want fuel sitting for too long in the tank.
Two of my cars (apart from the V8 Hilux) are dual fuel. They rarely get driven on petrol.
Just a few.
Old 12-02-2006, 06:38 PM   #7
snypereb
[EBGLT]
snypereb's Avatar
Thats your decision mate however it sounds good cause it would keep all you pumps and stuff working a lubricated!!
[EBGLT]
