Stingray
Old 13-02-2006, 05:55 PM   #1
birdy
birdy
Cool lowered susp
Any body know how low i can legally go in sa since have to replace sls.New springs and shocks i have been told ? Want legal where do the boys in blue measure from so i can check before ordering as if not worth it may as well keep standard level. :
birdy :
birdy is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2006, 06:01 PM   #2
Allen
You win again, gravity!!!
Allen's Avatar
lowest that you can go is 100mm, that is measured from the lowest point of your car, depending on the car, it could be the chassis rails, exhaust or even sump...
1966 Fairlane 500 XL
Allen is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2006, 08:20 PM   #3
birdy
birdy
If it was including sump why would one lower their car or even how body to ground is what we strive for plus handling not to mention stance
birdy :
Old 13-02-2006, 08:44 PM   #4
EL_futuraistic
EL_futuraistic's Avatar
In victoria the legal limit is nothing under car can hang lower than 100mm from the road..... or basically cruise over a Ciggy packet which is 90mm without touching it.
Lowering your car can both improve handling, braking and looks of your car, but if not done properley it can still look good BUT also dramatically decrease your handling, steering, braking capabilities, not to mention wearing out your tyres.
If you go on your RTA website you should be able to print off the regulations, or indeed a quick call to ur local RTA office and im sure they can mail it out to you.
EL_futuraistic is offline   Reply With Quote Multi-Quote with this Post
