Old 14-02-2006, 06:02 PM   #1
bab
Default Temp reading on ef 11
i recently installed a new radiator in my ef and whilst temp gauge sits on the low side of normal most of the time but the other day i had a full load of people in car and was climbing a steep hill of about 2 k'S when gauge went up to close to "o" ,and as road levelled off it quickly went down to the low part of gauge,is this normal, ps it was a hot brisbane day,i beleive you can alter fan switch to come on earlier,will this help and how do you alter fan setting ?
bab is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2006, 08:02 PM   #2
vanessa0305
vanessa0305's Avatar
Did you have the a/c on? Have you checked your cooling systems for leaks? Had it pressure tested? Are we talking NORMAL down the cluster or across the cluster? Mine is down and I am assuming yours is too as otherwise the O wouldn't be too hot.
That's very warm and I have always been told that if it goes past half way (between the r and m in my car) to turn the a/c off and pull over till it cools or I risk my head gasket. However since having my radiator flushed, cleaning out between my radiator and condenser and having the thermostat housing changed and the system filled with Prixmax and pressure tested my car has never gone above the low part of M and that was when (with out a/c) we drove up the Toowoomba range with a full load of 6 in the car.
vanessa0305 is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2006, 08:10 PM   #3
svo347
AFF's 1st DM.......
svo347's Avatar
the temp being at the "O" in NORMAL is fine mate
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 14-02-2006, 09:12 PM   #4
efgiar
rofl copter
efgiar's Avatar
lol "doesnt normal mean blown headgasket"
o is fine, any higher and i would be a little worried, if u didnt kno the engine heats up to at least o every time u turn it off after it reaches running temp...
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2006, 10:22 PM   #5
AshMan
Girrrrr!!!
AshMan's Avatar
Mate, maybe you could put the dash into diagnostic mode, get the actual engine temp up, then post that up and see what it is...
It could even be your sender that isn't working properly, although I'm sure the O in normal isn't all that bad...
Falcon EF XR6 in Heritage Green
Heritage green, isn't that a fence paint?
AshMan is offline   Reply With Quote Multi-Quote with this Post
Old 15-02-2006, 10:11 AM   #6
bab
Default thanks
thanks for info,i feel a lot better now that "o" can be normal
