Old 22-02-2006, 01:58 PM   #1
efgiar
rofl copter
efgiar's Avatar
Default elec window playing?
my lhf window motor is playing games, sometimes it will work, and then it wont, i hit it and fidle with the wires etc but doesnt seem to efect it... worth pulling it apart and try to isolate the problem or just buying a new one?
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2006, 04:20 PM   #2
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
Sounds like a loose contact. You could replace the regulator, but I reckon it would be a waste of money. Have you checked the buttons are all fine and the contacts are clean?
Does the window wind up & down normally when its working, or does it jump, shudder etc?
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2006, 04:30 PM   #3
hako
hako's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Regularly gives valued, considered advice to others.
On our EB Fairmont the problem was a dud console switch - swapped wires around so the dud one was a rear window that was never used.
hako is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2006, 04:43 PM   #4
defa
GTP0075
defa's Avatar
I also have a similar problem with my EF the window regs are a common problem we sell lots of these regs. but would not hurt to check connections first as regs are riveted in and can take a while to get out.
defa is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2006, 05:12 PM   #5
EA2BA
PM me if you want
EA2BA's Avatar
I just re-solder the all the contacts they seem to go dry joint and stop making contact, fixed mine up when the passenger window went down and never to come back up. Also worked on my SLS that at times would to fail and not work.
Old 22-02-2006, 10:00 PM   #6
efgiar
rofl copter
efgiar's Avatar
it goes up and down fine, wen it works, i havnt played with it since but will do tomorow, ill pull it out clean, resolder joints etc and see how i go, if it doesnt work it wont be getting fixed for a while :(
GQ patrol.
thats all
Old 22-02-2006, 10:01 PM   #7
efgiar
rofl copter
efgiar's Avatar
it could be the buttons, altho the lights dim a little wen u push it so i highly doubt it, i thaught that also as they have a tendancy to go. will inspect it more tomorow.
GQ patrol.
thats all
Old 22-02-2006, 10:24 PM   #8
sphell
sphell's Avatar
next time it doesn't work, pull out the switches and check for power with a test light. If it has power when you press the switch, move to the door. Take off the trim and check for power at the window reg. If it has power there then it's the reg...if not, its a wiring problem between the door and switch.
