Old 23-02-2006, 03:15 PM   #1
Growler
Growler's Avatar
Default Motor swap
If my compression test on my 300,000+ EF motor fails i will look into swapping it for a low kms wreck motor. What is involved in swapping it over?
Is it a matter of simply disconnecting the simple stuff, jacking up the motor from underneath, undoing the engine mounts and unbolting the auto trans and then on a hoist removing the old and chucking in the new?
What's the deal with the transy, does it need a new seal and rear main oil seal?
How much should i expect to pay for a low km's EF or EFXR6 motor?
Thankyou for reading and answering my thread.
GROWLER
Growler is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2006, 03:30 PM   #2
EA2BA
PM me if you want
EA2BA's Avatar
you will need an engine crane to remove the engine, and i strongly suggest remove the bonnet, then remove negine and gearbox together. Get a front and rear gearbox seal.
Old 23-02-2006, 03:30 PM   #3
efgiar
rofl copter
efgiar's Avatar
if i was doing id replace all possible seals that are the hardest/most expensive to do whilst in the car, eg rear main, sump, check and replace welsh plugs as needed. because in the end it will cost u alot more if u dont do it proply the first time. you just undo stuff till it looks like its going to come out then try pull it out very slowly and undo/unplug anything that remains.
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2006, 08:21 PM   #4
Papa Smurf
Papa Smurf's Avatar
If you have Air Conditioning, just remove the A/C compressor and try to hold it out of the way. Better than letting the GAS out? it's not exactly legal to do in yoru Back Yard?
If you were able to find someone who has a hoist? you could do like we do at work with BA's and remove the motor and Gearbox and Crossmembers from underneath.
Papa Smurf is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2006, 09:29 PM   #5
snypereb
[EBGLT]
snypereb's Avatar
Big job mate hope all works out do it properly no short cuts and make sure you get a reasonable engine
[EBGLT]
Old 27-02-2006, 11:40 AM   #6
Growler
Growler's Avatar
TY,
How much time are we looking at for a motor swap? 1 day or more???
Old 27-02-2006, 11:53 AM   #7
XRated
Shoot.
XRated's Avatar
Shouldn't take you more than a day if you know what you're doing.
20V Turbo
Old 27-02-2006, 12:29 PM   #8
efgiar
rofl copter
efgiar's Avatar
1 person can take out a motor and box in less then 2 hours. then doing seals etc then refittiing it would take 2-3 possibly even 4 hours. just depends on how much of a quality eye u have
GQ patrol.
thats all
Old 27-02-2006, 03:46 PM   #9
jpiez
i just swapped motors in my eb yesterday... took me n my old man 9 housr to pull it out n build the otherone from the head gasket up... just gota connect all the hoses n wires n modify the exhaust tonight
jpiez is offline   Reply With Quote Multi-Quote with this Post
